kindly help me in making a simple compiler program using C++ language...
Quoting - chryne
The compiler is not a simple program... You may try to search the web for it.
You might consult Knuth's books.
I would suggest you begin with writing an interpreter. In this way you do not have to establish an object file format and then write your own linker and runtime system.
Once the interpreter is written, verifying your language constructs, then you can work on the other components (object file format, linker, runtime system, libraries,...) that typically accompany a compiler.
I would have to guess your request is for a CS project.
Jim Dempsey
