Intel® C++ Compiler
7932 Discussions
how to get a vaild serial # for icc compiler 9.0
whzlz-icc
I registered and downloaded Intel C++ Composer XE for Linux with a serial #. Then, I download icc compiler 9.0 from the drop-down meun. However, I can not install the compiler 9.0 using the serial #. how/where can I get a serial # for the icc compiler 9.0?
thanks.
whzlz-icc
TimP
Black Belt
I'm guessing you're talking about your license. If you need a new copy of your license file, you can ask for one by email at https://registrationcenter.intel.com If you are having difficulty with the entry of your license key during installation, you can use the alternate method referring to your license file.
For more difficult issues, you should ask (with a private message if necessary) on the licensing support forum.
whzlz-icc
Thank you very much for your reply.
I just need icc 9.0 (non-commericial) serial # for installation. I have ifort 9.0 and wanted to use them to develop some of my own research program (non-commericial usage).
I have downloaded l_ccompxe_2011 with a serial # (but not installed yet) and also downloaded icc 9.0 from the same page (drop-down menu), but was not given another serial #. The serial # for l_ccompxe_2011 doesn't work for icc 9.0. how to get a serial # for icc 9.0?
Current website (below) shows all lates non-commericial products, no older versions.
http://software.intel.com/en-us/articles/non-commercial-software-download/
Alternatively, which link should I use, in order to download the old version icc 9.0?
thanks again.
levicki
Valued Contributor I
I may be wrong, but I don't think it is possible to get older versions. There is also no good reason why you would want to use 9.0 instead of latest (12.0) compiler.
whzlz-icc
what I need is icc and ifort (linux version), currently I have ifort 9.0 on my machine. I have downloaded l_ccompxe_2011 (1.2G), but I am not sure if it is the latest 12.0. Anyway, do you have the link to 12.0?
thanks!
Om_S_Intel
The latestis Intel C++ Composer XE update 6,Date posted: 23 Aug 2011 Version: 2011 Build: Update 6 Build date: 11 Aug 2011.
