I have:
#define pp_il_element(...) (1, __VA_ARGS__ pp_empty)()
I want
pp_il_element()
expand to
(1, pp_empty)()
but icc 110 expand it to
(1 pp_empty)()
There is a comma lost.
I tested this on gcc, gcc expands this to
(1, pp_empty)()
gcc is ok.
Quoting - churunmin
I have:
I want
pp_il_element()
expand to
(1, pp_empty)()
(1 pp_empty)()
(1, pp_empty)()
gcc is ok.
I am investigating this issue. Could you provide code segment that compiles with gcc?
On Windows, both icl and cl expands to the same "(1 pp_empty)" with following define.
But on Linux, icc 11.0.081 expands just like gcc.
Here is the t.c I used:
typedef enum { pp_empty, pp_empty1, pp_empty2} SEnumT;
int foo(int a, SEnumT b)
return a+b;
int main(int argc, char* argv[])
foo pp_il_element();
return 0;
