Intel® C++ Compiler
7833 Discussions
icc 13 + Xcode 4.6.2 Invalid object files, bug?
theigors
Hi All
I'm using ICC for OSX (m_ccompxe_2013.3.171.dmg) with Xcode 4.6.2 and I've a problem:
- if "Generate Debug Info" = on, then all is Ok. However, if off, then link fails. Looking undersolved symbols I've noticed that corresponded object file (.o) is invalid and always has length 152 bytes. Changing source I force recompiling and .o file becomes Ok, but the issue repeats at next rebuild. What am I doing wrong? Or it's a bug?
SergeyKostrov
Valued Contributor II
Could you post a linker output, please?
theigors
Hi, Sergey, thx for your input
The link output is in attached zip. There is also invalid (.o (bad)) file (size 152) that produces unresolvеd(s). When I check the source, then a normal file is compiled (.o (good)), and other link errors produced (with next invalid .o), When I clean prj and rebuild from scratch - all happens again, and other .o files are invalid. The problem disappear if I set "Generate Debug Information" = on
SergeyKostrov
Hi, >>...Looking undersolved symbols I've noticed that corresponded object file (.o) is invalid and always has length 152 bytes. >>Changing source I force recompiling and .o file becomes Ok, but the issue repeats at next rebuild. What am I doing >>wrong? Or it's a bug? I see that there are only linker errors, like: ... Undefined symbols for architecture i386... ... It is clear that a library, for some Camera API, is "missing" for i386 architecture during your 1st attempt to build an executable. I admit that something is wrong and please review project linker settings for that configuration. >>...The problem disappear if I set "Generate Debug Information" = on... That looks like some internal problem with a linker.
theigors
IMO linker must fail if it receives corrupted .o files (junk in - junk out)
SergeyKostrov
>>>> That looks like some internal problem with a linker. >> >>IMO linker must fail if it receives corrupted .o files (junk in - junk out) Try to do a test: - Create a simple C/C++ project that uses one library ( any ) - Write a simple code that calls at least one function from the library - Corrupt the library ( in editor, for example ) - Try to build an executable - Post an error message from a linker for review Thanks in advance.
theigors
>> Try to do a test:
What is such test for? To prove that link fails with corrupted lib? I agreed 100% even without any test :-) Here I know why produced lib is incorrect - because some sources aren't compiled properly. Sorry if I've not explained this well.
