Compiler version and platform:
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.0.098 Build 20160721
The code compiles successfully with -std=c++11, but crashes the compiler with -std=c++14.
$ icc -c -std=c++11 small.cpp $ $ g++-6.2 -c -std=c++14 small.cpp $ clang++-3.8 -c -std=c++14 small.cpp $ $ icc -c -std=c++14 small.cpp small.cpp(9): internal error: assertion failed at: "shared/cfe/edgcpfe/interpret.c", line 3438 } b (&b.v[1]); ^ compilation aborted for small.cpp (code 4) $ $ cat small.cpp struct A { int v[2]; }; struct B : A { constexpr B (int *p) : A () {} } b (&b.v[1]); $
I reproduced this bug with 17.0 Update 1 as well:
$ icc -c -std=c++14 test.cpp
test.cpp(9): internal error: assertion failed at: "shared/cfe/edgcpfe/interpret.c", line 3444
} b (&b.v[1]);
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
I will escalate this to the developers to fix it.
DPD200415968 is for your reference.
