Intel® C++ Compiler
icc 17.0.0 rejects valid C++ code with template class inheritance
Zhendong_Su
Compiler version and platform:
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.0.098 Build 20160721
$ g++-6.2 small.cpp
$ clang++ small.cpp
$ icc small.cpp
small.cpp(14): error: no instance of function template "foo" matches the argument list
            argument types are: (A<D, C>)
    foo (a);
small.cpp(9): note: this candidate was rejected because at least one template argument could not be deduced
  template < class T > void foo (const A < T, B > &) {}
compilation aborted for small.cpp (code 2)
$ cat small.cpp
template < class T, class S > struct A {};
struct B {};
struct C {};
struct D {};
template < class T > struct A < T, B > {};
template < class T > struct A < T, C > : public A < C, B > {};
int main ()
  A < D, C > a;
  foo (a);
  return 0;
Varsha_M_Intel
Please allow me sometime to reproduce and debug this issue. I will update you as soon as I am able to reproduce.
Varsha
Varsha_M_Intel
I have raised this issue to the Engineering team. I will let you know as soon as the fix is available.
Varsha
Judith_W_Intel
I doubt that the code is legal -- Both Microsoft and the clang compiler give a similar error.
Zhendong_Su
Judith, I think it should be valid.  BTW, it's accepted by the latest clang.
Brent_C
Just ran into this same bug on icpc version 19.0.4.243. Any chance this will get fixed?
