Intel® C++ Compiler
7956 Discussions
icc 17.0.0 rejects valid C++ code with variable argument function
Zhendong_Su
Compiler version and platform:
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.0.098 Build 20160721
The latest clang also incorrectly rejects the code.
$ g++-6.2 -Wall -Wextra -pedantic -std=c++14 small.cpp
$ icc -std=c++14 small.cpp
small.cpp(12): error: a non-POD (Plain Old Data) class type cannot be fetched by va_arg
    A v = va_arg (a, A);
small.cpp(19): warning #1595: non-POD (Plain Old Data) class type passed through ellipsis
    foo (t, t);
compilation aborted for small.cpp (code 2)
$ cat small.cpp
#include <cstdarg>
struct A
  virtual ~A () {}
void foo (A p, ...)
  va_list a;
  va_start (a, p);
  va_end (a);
int main ()
  A t;
  foo (t, t);
  return 0;
Varsha_M_Intel
Please allow me sometime to reproduce and debug this issue. I will update you as soon as I am able to reproduce.
Varsha
MalReddy_Y_Intel
Hi
 This issue has been escalated to engineering team, will check status and keep update you.
Reddy
MalReddy_Y_Intel
This issue is addressed in the 17.0 up4 compiler, hence closed it.
