Intel® C++ Compiler
icc 17.0.1 miscompiles valid C code at -O2 (only) on x86_64-linux-gnu
Zhendong_Su
Compiler version and platform:
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
$ icc -Os small.c; ./a.out
$ icc -O3 small.c; ./a.out
$ icc -O2 small.c
$ ./a.out
Segmentation fault (core dumped)
$ cat small.c
int a, *b, c, d;
int fn1 ()
  int e = 0;
  for (; e < 4; e++)
    if (d && *b)
      break;
  if (e & a)
    while (1)
  return c;
int main ()
  fn1 ();
  return 0;
Igor_V_Intel
I escalated this bug to the developers (DPD200416561). Looks like it happens due to bug in vectorizer.
Igor_V_Intel
The pointer b is initialized to the correct null pointer value, however, we can't access an object using * operator. There is a bug in the code.
Zhendong_Su
Igor, no, the code is valid because d = 0 and && has short-circuiting semantics, so *d won't be executed.  It is an ICC miscompilation bug.
sergei_v_
I confirm the same Segmentation fault happens with my installation of icc.
