I am trying to compile our project with icc with -mavx option, and it cannot recognise gcc built-ins from avxintrin.h (such as __builtin_ia32_loadupd256 and __m256d). We don't include the header directly, it comes from tbb headers through immintrin.h header. How can I fix this issue? Or is gcc 4.7 just too old for icc 17, i.e. not supported?
Update: it looks like Intel compiler looks in gcc headers for immintrin.h, even when I supply only Intel include directory on command line. Is gcc include dir picked from some env variables?
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you provide us a test case to investigate?
I figured today that icpc was a bash shell that set up some variables and invoked the compiler, icpcbin. Then I tried icpcbin directly, and it worked, so the error comes from the setup done by icpc. It is this setup that directs icpcbin to gcc headers.
The test case:
command line:
/xenv/ICC/X/17.0/bin/icpc -o test.exe -c test.cpp -m64 -O3 -unroll8 -mavx -I/xenv/ICC/X/17.0/include/icc
Source file:
#include "/xenv/ICC/X/17.0/include/icc/immintrin.h" //case 1 //#include <immintrin.h> //case 2
Case 1 produces following errors:
/xenv/C++/ia64/4.4.7r11_64/RH6.6AS_64/usr/lib/gcc/x86_64-redhat-linux/4.4.7/include/wmmintrin.h(34): error: #error directive: "AES/PCLMUL instructions not enabled" /xenv/ICC/X/17.0/include/icc/immintrin.h(31): error: expected an identifier typedef union _MMINTRIN_TYPE(32) __m256 { /xenv/ICC/X/17.0/include/icc/immintrin.h(31): error: expected a ";" typedef union _MMINTRIN_TYPE(32) __m256 {
(the last two errors repeat for all __m256 typedefs)
When immintrin.h is included explicitly from ICC directroy, the headers included from within immintrin.h are picked from gcc directories due to setup created by icpc script.
Case 2 produces following errors:
xenv/C++/ia64/4.4.7r11_64/RH6.6AS_64/usr/lib/gcc/x86_64-redhat-linux/4.4.7/include/avxintrin.h(847): error: no declaration for "__m256d"; missing #include directive return (__m256d) __builtin_ia32_loadupd256 (__P); ^ /xenv/C++/ia64/4.4.7r11_64/RH6.6AS_64/usr/lib/gcc/x86_64-redhat-linux/4.4.7/include/avxintrin.h(847): error: identifier "__builtin_ia32_loadupd256" is undefined return (__m256d) __builtin_ia32_loadupd256 (__P); ^
(again, the errors are repeated for all __m256 types)
This time immintrin.h is included from the direcory set up by icpc script, which is the gcc include dir. As a result, ICC cannot recognize gcc built-ins (because in ICC the intrinsics are not based on built-ins).
By the way, icpc script in our installation has a typo at the end, $ICC} instead of ${ICC}, which gets invoked when the script is run without parameters. Please check if the typo exists in the latest version.
Did you source the compilervar before invoke it?
I hadn't; I just did, but it didn't help - same errors...
I couldn't be able to reproduce it on my system.
vahoang@orcsle100:/tmp$ icpc -o t.out t.cpp -m64 -O3 -unroll8 -mavx -I/cts/tools/compiler/cpro/Compiler/17.0/update_2/compilers_and_libraries_2017.2.174/linux/compiler/include/icc/immintrin.h -c
vahoang@orcsle100:/tmp$ cat t.cpp
#include"/cts/tools/compiler/cpro/Compiler/17.0/update_2/compilers_and_libraries_2017.2.174/linux/compiler/include/icc/immintrin.h"
//#include<immintrin.h>
//#include"/cts/tools/compiler/cpro/Compiler/17.0/update_2/compilers_and_libraries_2017.2.174/linux/compiler/include/icc/immintrin.h"
vahoang@orcsle100:/tmp$ gcc -v
gcc version 4.4.4 20100726 (Red Hat 4.4.4-13) (GCC)
could you please show the environment variables used by icpc script?
I just "source compilervars.sh intel64" prior to invoking icpc
