I've found icc18 renaming symbols internally. Basic test.cpp:
extern "C" { void omp_set_num_threads(int num_threads); } void somefun(void) { omp_set_num_threads(3); }
Attempt to compile with:
$ icpc test.cpp /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' /tmp/icpcY3L2xB.o: In function `somefun()': test.cpp:(.text+0x6): undefined reference to `ompc_set_num_threads'
Essentially: The omp_set_num_threads has been renamed to ompc_set_num_threads, as though it were a magic name being handled specially internally to the compiler?. Even if this was required, I've not enabled openmp. This specific sample just shows the renaming - I'm not expecting it to otherwise compile - we've got code in our project that stubs out openmp if OpenMP is not turned on, and this transformation breaks the code (because it links to a stub where omp_set_num_threads definitely exists, but is no longer looking for that symbol).
icc 17 doesn't have this issue. Why is it here, and how do I turn it off?
I see omp_set_num_threads has been renamed, but it's defined in libiomp5; you would need to link with -qopenmp to resolve it.
In this specific case, I didn't want to -qopenmp. I want my own symbol called omp_set_num_threads, and to link to this in cases where we don't want to enable openmp (the project I'm working on has written an empty abstraction so that they can write openmp control code with or without openmp turned on, without having to #ifdef, and to python wrap. I'm not saying that this is a good approach, but unfortunately it's the one we've got).
Attached is a complete example with makefile that compiles and runs on icc17 but gives the same error as above on icc18. A file with the contents stub.cpp:
extern "C" void omp_set_num_threads(int) { }
Should define the symbol, and and correctly does, whether compiled as static:
$ icpc -c stub.cpp -o stub.o $ nm stub.o U __gxx_personality_v0 0000000000000000 T omp_set_num_threads
Or shared:
$ icpc -shared -fPIC stub.cpp -o libstub.so $ nm libstub.so | grep threads 0000000000000750 T omp_set_num_threads
I should then be able to link to this symbol (indeed, this is the most basic example of sharing codes between translation units) by just declaring it and specifying the library to link (shared) or object file to include (static) e.g.
// Explicitly declare, *not define* the function so we can call it extern "C" void omp_set_num_threads(int); int main(int, char**) { omp_set_num_threads(4); }
And then compile (static version, to avoid -L path complexity) with
$ icpc -o main main.cpp stub.o
But this fails on icc18 with the above ompc_set_num_threads error, even though that's not a symbol I've used anywhere in my program. As a simple test cross-section, icc17, gcc4.8.5 and clang5.0 works fine. icc18 seems to treat openmp symbols as special and rename them, even if openmp hasn't been turned on with -qopenmp. Since to my knowledge no compiler allows you to swap out the openmp implementations at runtime this is perhaps justifiable, but surely not when openmp isn't requested?
As far as I'm aware omp_set_num_threads isn't a protected symbol and theoretically I should be allowed to define it myself? My question is whether this can be turned off, and, I guess, are there any otherwise valid symbols that I'm not allowed to use with icc?
Viet,
I agree with Nicholas that the compiler should not rename the user supplied symbols. Consider additional factors to Nicholas's desire to use his own stubs.
a) Use of previous compiled static lib or .dll having format without renaming.
b) Use of older Intel libiomp5 (due to bug in newer libiomp5 or difference in implementation).
c) For reasons known to user, compile code to be linked with GCC OpenMP runtime library.
Jim Dempsey
Hi Nicholas,
Thankd for your test case. It's clear to me now. I just reported this issue to our developer and will keep you posted.
Viet
Internal bug number is: CMPLRIL0-30689
I agree the Intel compiler behaves not user friendly in this particular case. Though the intention to implement own OpenMP runtime and use it with Intel compiler which has its own runtime looks unclear in general. This use case does not look reliable in general. Would it be better to just use stubs library provided by the compiler? This is simple, just specify -qopenmp-stubs compiler option. BTW, declaring OpenMP interfaces manually is also not a conforming way to use OpenMP runtime APIs, as the specification requires to include standard header omp.h for this.
-- Andrey
For more complete information about compiler optimizations, see our Optimization Notice.
