I think I found a bug in intel c compiler. This is how to reproduce it:
First file (cstuff.c)
#include <stdio.h> #include <string.h> #include <netdb.h> #include <sys/utsname.h> #include <sys/socket.h> void uninf(char sy[],long *l) { struct hostent *h ; struct utsname inf ; char lsy[1000]; int ll ; uname(&inf) ; if ( (h = gethostbyname(inf.nodename)) == NULL) { printf("gethostbyname>hostname problem: "); printf("check /etc/hosts or /etc/resolv.conf\n"); sprintf(lsy,"%s-%s(%s)", inf.sysname, inf.release, inf.machine); } else { sprintf(lsy,"%s-%s(%s)@%s", inf.sysname, inf.release, inf.machine, h->h_name); } //ll = strlen(inf.sysname)+strlen(inf.release)+strlen(inf.machine)+strlen(h->h_name)+4; printf("%s\n", lsy); ll = (int) strlen(lsy) ; if (ll > 80) ll = 80; *l = ll ; //*l = ( *l > 44 ) ? 44 : *l ; //ll = *l ; strncpy(sy,lsy,ll); }
Second file: (teststr.c)
#include <stdio.h> #include <string.h> void uninf(char sy[], long *l); int main(int argc, char **argv) { char s[120], s2[120]; long i; uninf(s, &i); strncpy(s2, s, i); s2[i+1] = '\0'; printf("%s\n", s2); return 0; }
Compile both files:
icc -g -O3 -c cstuff.c
icc -g -O3 -c teststr.c
and link them:
icc -g cstuff.o teststr.o -o strtest
The program strtest causes a SEGILL error on certain machines (compiled on Redhat Enterprise Linux server 6.8, kernel version 2.6.32-642.3.2.e16.x86_64; running on Redhat ELS 7.0 Maipo with kernel 3.10.0-123.e17.x86_64)
While it does not cause segfault on all machines, running strtest in gdb:
(gdb) start Temporary breakpoint 1 at 0x400af8: file teststr.c, line 8. Starting program: /users/dzhang/tmp/strlenbug/fail.exe Temporary breakpoint 1, main (argc=0, argv=0x3) at teststr.c:8 8 uninf(s, &i); Missing separate debuginfos, use: debuginfo-install glibc-2.17-55.el7.x86_64 libgcc-4.8.2-16.el7.x86_64 (gdb) s 4 int main(int argc, char **argv) { (gdb) s 8 uninf(s, &i); (gdb) s uninf (sy=0x7fffffffe300 "\b\342\377\367\377\177", l=0x7fffffffe3f0) at cstuff.c:9 9 { (gdb) s 15 uname(&inf) ; (gdb) s 16 if ( (h = gethostbyname(inf.nodename)) == NULL) { (gdb) s 21 sprintf(lsy,"%s-%s(%s)@%s", inf.sysname, inf.release, inf.machine, (gdb) p sy $1 = 0x7ffff78c1e20 <resbuf.11716> "\305A`" (gdb) s 25 printf("%s\n", lsy); (gdb) p sy $2 = 0x0
The address of sy changes to 0x0 at the end. Compile with gcc -g -O3 or icc -g -O0 does not show this behavior.
Previously we used intel C++ compiler 11.0.074 and we did not see the same crash.
I realize that the memory issue I mentioned in GDB might be due to the fact that these symbols were generated before the optimization. Nevertheless, the same code does not crash with earlier version the intel compiler.
What happens when you declare ll as long? (IOW *l = ll; fails to promote)
Alternatively, what happens when you use: l = (long)ll;?
If either/both work then the you have located the compiler bug.
I recall similar bugs several years ago where a promotion was not performed.
Jim Dempsey
Thanks, Jim. I found out the reason now. See below.
Jim Dempsey
Sergey Kostrov wrote:
>>...The program strtest causes a SEGILL error...
Simply to let you know that this is a signal for Illegal Instruction.
Your comment just helped me to realize what happened. It turns out that I also have the -xHost option for the CFLAGS. This caused the illegal instruction for another machine.
Question to Intel engineer:
We have been using the -xHost flag for many years and this is the first time we saw this error. What has changed between icc 11.0 and 2016.1? Is this a bug that needs to be fixed?
