All,
I am working on a project using wxWidgets cross platform library. In order to reduce size & increase optimization of my binaries I have tried using the icc 8 compiler (linux). It installed fine and I was able to compile some projects in order to eval the compiler. Unfortunately, my gcc compiler has not worked ever since installing this thing. I get errors when attempting to compile. Nothing has changed at all other than I installed the icc 8 compiler. Here is one of the errors I get (this one is when trying to do a make on my wxWidget libs):
In file included from /usr/include/bits/sigcontext.h:28,
from /usr/include/signal.h:326,
from ../src/common/appbase.cpp:43:
/ usr/include/asm/sigcontext.h:79: error: syntax error before `*' token
make: *** [basedll_appbase.o] Error 1
I have tried removing the compiler but still no luck.
Any ideas?
Bryan Ashby
Any ideas?
Bryan Ashby
Ok I figured it out -- a few files from glibc-devel-2.3.3-10mdk.rpm had been removed. I'm not sure how this happened, as like I said all I did was install the icc 8 compiler. I will try again and report back if the issue continues.
Thanks again,
Bryan Ashby
Thanks again,
Bryan Ashby
Dear Bryan,
This is good to hear. As far as I know, our installation and compiler do not attempt to write anything outside of the standard /opt/intel_cc_80 directory. We of course rely on headers and libraries outside of our compiler directories, but for read only purposes.
Max
