$ icc --version
icc (ICC) 19.1.2.254 20200623
fftw is 3.3.8
$ ./configure --prefix=/shared/ --enable-sse2 --enable-avx --enable-shared=no --enable-static=yes --disable-doc F77=ifort CC=icc
appears to run fine, but
$ make
libtool: compile: icc -no-gcc -DHAVE_CONFIG_H -I. -I.. -I .. -O3 -ansi-alias -malign-double -MT tensor.lo -MD -MP -MF .deps/tensor.Tpo -c tensor.c -o tensor.o
tensor.c(31): error: identifier "__INT_MAX__" is undefined
if (FINITE_RNK(rnk) && rnk > 1)
if i hack the configure file and replace "-no-gcc" to "-gcc-sys" then compiling and check work fine (apparently).
this did not happen with 2019 version of icc.
is there a better solution since i don't want to hack fftw's configure? is this a bug in the current icc?
This is a known issue for icc version 19.1.2
There are several workaround:
1) Use icx instead of icc as you have noticed
2) remove -no-gcc
3) add -Qoption,cpp,--gnu_version=40805
4) use icc 19.1 update 1 (version 19.1.1.217 Build 20200306)
Viet
so, changing CC=icc to CC=icx, fftw 3.8.8 compiles/checks fine.
changing CC="icc -gcc-sys" does not (configure appends '-no-gcc').
We have tried all the steps you have mentioned in the issue. And we are able to reproduce this issue. So we are forwarding this issue to the concerned team, they will get back to you soon.
Warm Regards,
Abhishek
2) remove -no-gcc
Viet
Thank you.
I will roll back to icc 19.1 update 1 since i ran into another problem. namely w/ --enable-avx512 on AWS's c5 instance, fftw 3.3.8 fails to compile. i.e.:
$ ./configure --prefix="/shared/.mrm/intel" --enable-sse2 --enable-avx2 --enable-avx512 --enable-shared=no --enable-static=yes --disable-doc F77=ifort CC=icx
$ make
libtool: compile: icx -DHAVE_CONFIG_H -I. -I../../.. -I ../../.. -O3 -fomit-frame-pointer -mtune=native -fstrict-aliasing -MT n1fv_4.lo -MD -MP -MF .deps/n1fv_4.Tpo -c n1fv_4.c -o n1fv_4.o
In file included from n1fv_4.c:3:
In file included from ./../common/n1fv_4.c:82:
In file included from ../../../dft/simd/n1f.h:21:
../../../simd-support/simd-avx512.h:48:2: error: "compiling simd-avx512.h without avx-512f support"
#error "compiling simd-avx512.h without avx-512f support"
while
$ lscpu
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single pti fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx avx512f avx512dq rdseed adx smap clflushopt clwb avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves ida arat pku ospke
this did not happen with 2019 update4 on the same instance.
Seems like you use icx in this later case. Did it compile with icc? Can you provide us a preprocess file to take a look?
icx -DHAVE_CONFIG_H -I. -I../../.. -I ../../.. -O3 -fomit-frame-pointer -mtune=native -fstrict-aliasing -MT n1fv_4.lo -MD -MP -MF .deps/n1fv_4.Tpo -n1fv_4.c -E
Yes, i used icx (just assumed icc would have the same problem). Let me spin up a c5 and try w/ icc...
1) no, icc throws the same error as the original post
2) hacking configure to replace -no-gcc to -gcc-sys gives a successful compile/test of CC=icc
3) i've included config.log with CC=icx and the generated simd-support/simd-avx512.h. interestingly, both icx and icc generate the same simd-avx512.h.
You'll have to give me a bit more information (exactly what) if this is not sufficient.
I am interested in this error:
I guess, this how n1fv_3.c was compiled
$icx -DHAVE_CONFIG_H -I. -I../../.. -I ../../.. -O3 -fomit-frame-pointer -mtune=native -fstrict-aliasing -MT n1fv_4.lo -MD -MP -MF .deps/n1fv_4.Tpo -c n1fv_4.c -o n1fv_4.o.
If you cd to directory where n1fv_4.c resides, then run:
$icx -DHAVE_CONFIG_H -I. -I../../.. -I ../../.. -O3 -fomit-frame-pointer -mtune=native -fstrict-aliasing -MT n1fv_4.lo -MD -MP -MF .deps/n1fv_4.Tpo n1fv_4.c -E >& n1fv_4.i
and provide us n1fv_4.i
thanks for the instructions. i will do it, but it will take a bit of time...
meanwhile, if you do look at simd-avx512.h, you'll see the error- it tests two macros. i assume icx is failing on the first (i.e. __GNUC__) since icc w/ the hacked configure doesn't throw the error.
ok, you dont need to create a preprocess file anymore.
I'll need to find a machine with avx512f supports to try.
Can you try this on you system and let me know if it works with icc and fails with icx?
$icc t.c -c [some other options if you have]
$icx t.c -c [some other options if you have]
$ cat t.c
#if defined(__GNUC__) && !defined(__AVX512F__)
#endif
int foo() {
return 1;
on AWS c5(.xlarge):
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 85
Model name: Intel(R) Xeon(R) Platinum 8124M CPU @ 3.00GHz
Stepping: 4
CPU MHz: 3400.482
BogoMIPS: 6000.00
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 1024K
L3 cache: 25344K
NUMA node0 CPU(s): 0-3
$ cat t.c
#endif
int foo() {
return 1;
$ icx t.c -c -mtune=native
t.c:2:2: error: "compiling simd-avx512.h without avx-512f support"
1 error generated.
compilation aborted for t.c (code 1)
$ icc t.c -c -mtune=native
t.c(2): error: #error directive: "compiling simd-avx512.h without avx-512f support"
compilation aborted for t.c (code 2)
$ icc t.c -c -mtune=native -gcc-sys
It's related to -gcc-sys option, which currently isn't supported in icx.
If you run: $icx t.c -c -mtune=native -gcc-sys,I think you
would see a warning message about unsupported option
AFAIK, it will be support in the future.
yes, -gcc-sys is not supported w/ icx.
i'll rollback to 2020 update 1.
fyi- 2020 update 1 icc compiles fftw 3.3.8 as usual, including avx2 and/or avx512 w/o any hacks.
Perhaps update 3 will go back to a clean compile.
Thanks again!
This issue is fixed in oneAPI2021.2.
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
I am going to close this thread.
