Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7728 Discussions
icc: bug: __builtin_mul_overflow: wrong overflow value when casting type
KamilCuk
[Godbolt.com link](https://godbolt.org/z/aecPTaxc3). The following code:
#include <stdio.h>
#include <limits.h>
void test(unsigned a) {
unsigned c1;
int o1 = __builtin_mul_overflow((int)a, 1, &c1);
printf("%d %u %d\n", (int)a, c1, o1);
int main() {
test(-1);
test(INT_MIN);
When compiled with gcc produces:
-1 4294967295 1
-2147483648 2147483648 1
However, when compiled with icc 2021.1.2 produces:
-1 4294967295 0
-2147483648 2147483648 0
`(int)a` value is negative, so negative multiplied by 1 is still negative, so it
does not fit into unsigned type, so overflow should be set.
Seems like `__builtin_mul_overflow` ignores the cast and works as-if `(int)a` has
`unsigned` type. One workaround is just to use a temporary variable instead
of a cast:
int a1 = a;
int o1 = __builtin_mul_overflow(a1, 1, &c1);
VarshaS_Intel
Thanks for reporting us.
We are working on this internally and will get back to you soon. Meanwhile, you can try using the Intel icx compiler to get the expected results.
Thanks & Regards
Varsha
Viet_H_Intel
Can you use a workaround or icx/icpx? I would recommend using icx/icpx because at some point, the classic C/C++ compilers will enter “Legacy Product Support” mode signaling the end of regular updates to the classic compiler base, and they will no longer appear in oneAPI toolkits.
Please see the article for more details:
https://www.intel.com/content/www/us/en/developer/articles/technical/adoption-of-llvm-complete-icx.h...
KamilCuk
Hey, thanks for responses!
Well, I am not a user of icc, and I'm not using icc in any production project. I only found the problem, when doing a research project with no current practical use. I was only testing "if it works" on icc compiler and stumbled across the problem when unit-testing. I was implementing ckd library https://gitlab.com/Kamcuk/ckd based on proposition to the standard http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2792.pdf . If it's for example not "worth fixing", that's "fine for me". I have a path in the library that does not use any `__builtin` functions, and it works fine on icc anyway.
Sure, `icx -xc` works fine.
Viet_H_Intel
As a workaround in icc, a temporary variable can be used:
int x = a;
int o1 = __builtin_mul_overflow(x, 1, &c1);
We are going to close this issue as "wont fix".
Sorry for the inconvenience.
