Intel® C++ Compiler
icc bug while compiling fmtlib
Wiener__Rafi
I tried compiling fmtlib (a text formatter library) with ICC v15-v17.
it compiles well with gcc4.8.5+ and clang but icc reported issues.
i opened an issue in their github and found a workaround for compilation of the core library, but not for the fmtlib tests.
the developer suggested to update the intel team since he thinks it's an ICC bug.
you can see the full discussion here
https://github.com/fmtlib/fmt/issues/822
Thanks Rafi
Viet_H_Intel
Can you provide us a preprocess file (literals.i), your command line options and the compiler version?
Viet
Wiener__Rafi
i have no idea what is the literals.i file
this is how to reproduce
  • clone fmtlib
git clone https://github.com/fmtlib/fmt
  • checkout the commit before the fix
cd fmt
git checkout c684349195c1
build
build with icc v15-17
mkdir build
cd build
cmake .. -DCMAKE_CXX_COMPILER=icpc -DCMAKE_CC_COMPILER=icc
make
i saw the issue with
Intel 15.0.1.20141023
Rafi
Viet_H_Intel
Hi Rafi,
15.0.1 compiler is too old.
You look into your command line options, then replace -c with -E, save the output to literals.i file and provide it to us if you still see the problem with ICC 18.0.
Viet
Wiener__Rafi
I still see it with ICC17
good enough?
Viet_H_Intel
Yes, please provide us a preprocess file.
Wiener__Rafi
This is the error i get with icc 17.0.1. same code compiles with gcc 4.8.5 and clang.
literals file attached
thanks
[ 69%] Building CXX object test/CMakeFiles/printf-test.dir/printf-test.cc.o
cd /git/fmt/build/test && /hpc/local/commercial/ics-2017-u1/compilers_and_libraries_2017.1.132/linux/bin/intel64/icpc  -DFMT_USE_ENUM_BASE=1 -DFMT_USE_FILE_DESCRIPTORS=1 -DFMT_USE_TYPE_TRAITS=1 -DGTEST_HAS_STD_WSTRING=1 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING=0 -isystem /git/fmt/test/gtest -isystem /git/fmt/test/gmock -isystem /git/fmt/test/. -I/git/fmt/include  -O3 -DNDEBUG   -fno-delete-null-pointer-checks -std=gnu++11 -o CMakeFiles/printf-test.dir/printf-test.cc.o -c /git/fmt/test/printf-test.cc
/git/fmt/include/fmt/core.h(574): error: no instance of function template "fmt::v5::printf_formatter<T>::format [with T=TestString]" matches the argument list
            argument types are: (const TestString, fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>)
            object type is: fmt::v5::printf_formatter<TestString>
      ctx.advance_to(f.format(*static_cast<const T*>(arg), ctx));
/git/fmt/include/fmt/printf.h(331): note: this candidate was rejected because at least one template argument could not be deduced
    auto format(const T &value, FormatContext &ctx) -> decltype(ctx.out()) {
          detected during:
            instantiation of "void fmt::v5::internal::value<Context>::format_custom_arg<T>(const void *, Context &) [with Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, T=TestString]" at line 557
            instantiation of "fmt::v5::internal::value<Context>::value(const T &) [with Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, T=TestString]" at line 583
            instantiation of "fmt::v5::internal::typed_value<Context, TYPE>::typed_value(const T &) [with Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, TYPE=fmt::v5::internal::custom_type, T=TestString]" at line 691
            instantiation of "std::enable_if<<expression>, fmt::v5::internal::typed_value<C, fmt::v5::internal::custom_type>>::type fmt::v5::internal::make_value<C,T,Char>(const T &) [with C=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, T=TestString, Char=char]" at line 989
            instantiation of "std::enable_if<IS_PACKED, fmt::v5::internal::value<Context>>::type fmt::v5::internal::make_arg<IS_PACKED,Context,T>(const T &) [with IS_PACKED=true, Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, T=TestString]" at line 1047
            instantiation of "fmt::v5::format_arg_store<Context, Args...>::format_arg_store(const Args &...) [with Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, Args=<TestString>]" at line 1066
            instantiation of "fmt::v5::format_arg_store<Context, Args...> fmt::v5::make_format_args<Context,Args...>(const Args &...) [with Context=fmt::v5::basic_printf_context<std::back_insert_iterator<fmt::v5::internal::basic_buffer<char>>, char, fmt::v5::printf_arg_formatter<fmt::v5::back_insert_range<fmt::v5::internal::buffer>>>, Args=<TestString>]" at line 604 of "/git/fmt/include/fmt/printf.h"
            instantiation of "std::string fmt::v5::sprintf(fmt::v5::string_view, const Args &...) [with Args=<TestString>]" at line 493 of "/git/fmt/test/printf-test.cc"
compilation aborted for /git/fmt/test/printf-test.cc (code 2)
make[2]: *** [test/CMakeFiles/printf-test.dir/printf-test.cc.o] Error 2
make[2]: Leaving directory `/.autodirect/mtrswgwork/rafiw/git/fmt/build'
make[1]: *** [test/CMakeFiles/printf-test.dir/all] Error 2
make[1]: Leaving directory `/.
Viet_H_Intel
Thanks for the .i file. I'll look into it and get back to you.
Viet
Viet_H_Intel
I've reported this to our developer. The tracker is CMPLRS-51956.
Viet
Viet_H_Intel
To Workaround: Change the derivation of internal::context_base inside basic_context to public instead of private.
Viet
