We found a compiler bug in Intel oneAPI 2022.2/2022.3 which is very annoying:
Does work:
Does not work:
Since we can't transit to icx compiler due to massive compiler bugs we try to update from Intel parallel studio 20.0.1 to Intel oneAPI 2022.3 classic. But we found this bug.
Also we get an icc compiler problem with -Wremarks and using tbb.
Best regards
Frank
Thanks for reporting this issue. We were able to reproduce it and we have informed the development team about it.
Thanks & Regards,
Varsha
Sorry for the inconvenience caused to you.
Intel C++ Compiler Classic (icc) is deprecated and removed in the oneAPI 2024.0 release. We recommend using the LLVM-based Intel oneAPI DPC++/C++ Compiler (icx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Please transition to use this compiler.
Thanks & Regards,
Varsha
Intel C++ Compiler Classic (icc) is deprecated and removed in the oneAPI 2024.0 release. We recommend using the LLVM-based Intel oneAPI DPC++/C++ Compiler (icx). Please check out the new versions of Intel oneAPI Toolkits for the latest features.
This thread will no longer be monitored by Intel. If you have any other queries, please start a new thread.
Thanks & Regards,
Varsha
