Intel® C++ Compiler
icc command can not be found
Li__Zhimake
I have a remote machine which has the intel compiler installed already. I can see the /opt/intel/compilers_and_libraries_2018.1.163 and  /opt/intel/parallel_studio_xe_2018.1.038 directories.
But the icc command can not be found. And I have tried to run:
source /opt/intel/bin/compilervars.sh intel64
and
source /opt/intel/compilers_and_libraries_2018.1.163/linux/bin/compilervars.sh intel64
These attempts didn't figure my problems.
Does anyone have some suggestions?
Viet_H_Intel
try to find if icc is there? $find /opt/intel/parallel_studio_xe_2018.1.038 -name icc
Li__Zhimake
Oh, there is no icc in the folder. It looks like the machine didn't install the icc component. Is there any way to add icc without re-installing the parallel studio?
Thank you!
Viet_H_Intel
You would need to reinstall it.
Li__Zhimake
Okay, I see. Thank you~
