Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
7749 Discussions
icc compiler 11.0.83 on php 5.2.9 compiler failure
carlseamicro_com
Basic Info:
Operating system: CentOS 5.2 32bit
PHP version: 5.2.9
Configuration Variable:
CC=/opt/intel/Compiler/11.0/083/bin/ia32
Configuration for PHP:
./configure --with-apxs2=/usr/local/apache/bin/apxs --prefix=/usr/local/apache/php --with-config-file-path=/usr/local/apache/php --enable-force-cgi-redirect --disable-cgi --with-zlib --with-gettext --enable-maintainer-zts
Description:
Compiled PHP 5.2.9 using Intel icc compiler 11.0.83 failed in creating libphp5.la
All files seemed to compile OK. At the very end, I got the following error message and libphp5.la does not get generated... The same configuration works fine with gcc...
/bin/sh /usr/local/src/php-5.2.9/libtool --silent --preserve-dup-deps --mode=link /usr/local/src/php-5.2.9/meta_ccld -I/usr/include -g -O2 -pthread -DZTS -prefer-non-pic -rpath /usr/local/src/php-5.2.9/libs -avoid-version -module ext/libxml/libxml.lo ext/pcre/pcrelib/pcre_chartables.lo ext/pcre/pcrelib/pcre_ucd.lo ext/pcre/pcrelib/pcre_compile.lo ext/pcre/pcrelib/pcre_config.lo ext/pcre/pcrelib/pcre_exec.lo ext/pcre/pcrelib/pcre_fullinfo.lo ext/pcre/pcrelib/pcre_get.lo ext/pcre/pcrelib/pcre_globals.lo ext/pcre/pcrelib/pcre_info.lo ext/pcre/pcrelib/pcre_maketables.lo ext/pcre/pcrelib/pcre_newline.lo ext/pcre/pcrelib/pcre_ord2utf8.lo ext/pcre/pcrelib/pcre_refcount.lo ext/pcre/pcrelib/pcre_study.lo ext/pcre/pcrelib/pcre_tables.lo ext/pcre/pcrelib/pcre_try_flipped.lo ext/pcre/pcrelib/pcre_valid_utf8.lo ext/pcre/pcrelib/pcre_version.lo ext/pcre/pcrelib/pcre_xclass.lo ext/pcre/php_pcre.lo ext/zlib/zlib.lo ext/zlib/zlib_fopen_wrapper.lo ext/zlib/zlib_filter.lo ext/ctype/ctype.lo ext/date/php_date.lo ext/date/lib/astro.lo ext/date/lib/dow.lo ext/date/lib/parse_date.lo ext/date/lib/parse_tz.lo ext/date/lib/timelib.lo ext/date/lib/tm2unixtime.lo ext/date/lib/unixtime2tm.lo ext/dom/php_dom.lo ext/dom/attr.lo ext/dom/document.lo ext/dom/domerrorhandler.lo ext/dom/domstringlist.lo ext/dom/domexception.lo ext/dom/namelist.lo ext/dom/processinginstruction.lo ext/dom/cdatasection.lo ext/dom/documentfragment.lo ext/dom/domimplementation.lo ext/dom/element.lo ext/dom/node.lo ext/dom/string_extend.lo ext/dom/characterdata.lo ext/dom/documenttype.lo ext/dom/domimplementationlist.lo ext/dom/entity.lo ext/dom/nodelist.lo ext/dom/text.lo ext/dom/comment.lo ext/dom/domconfiguration.lo ext/dom/domimplementationsource.lo ext/dom/entityreference.lo ext/dom/notation.lo ext/dom/xpath.lo ext/dom/dom_iterators.lo ext/dom/typeinfo.lo ext/dom/domerror.lo ext/dom/domlocator.lo ext/dom/namednodemap.lo ext/dom/userdatahandler.lo ext/filter/filter.lo ext/filter/sanitizing_filters.lo ext/filter/logical_filters.lo ext/filter/callback_filter.lo ext/gettext/gettext.lo ext/hash/hash.lo ext/hash/hash_md.lo ext/hash/hash_sha.lo ext/hash/hash_ripemd.lo ext/hash/hash_haval.lo ext/hash/hash_tiger.lo ext/hash/hash_gost.lo ext/hash/hash_snefru.lo ext/hash/hash_whirlpool.lo ext/hash/hash_adler32.lo ext/hash/hash_crc32.lo ext/iconv/iconv.lo ext/json/json.lo ext/json/utf8_to_utf16.lo ext/json/utf8_decode.lo ext/json/JSON_parser.lo ext/pdo/pdo.lo ext/pdo/pdo_dbh.lo ext/pdo/pdo_stmt.lo ext/pdo/pdo_sql_parser.lo ext/pdo/pdo_sqlstate.lo ext/pdo_sqlite/pdo_sqlite.lo ext/pdo_sqlite/sqlite_driver.lo ext/pdo_sqlite/sqlite_statement.lo ext/pdo_sqlite/sqlite/src/attach.lo ext/pdo_sqlite/sqlite/src/auth.lo ext/pdo_sqlite/sqlite/src/btree.lo ext/pdo_sqlite/sqlite/src/build.lo ext/pdo_sqlite/sqlite/src/callback.lo ext/pdo_sqlite/sqlite/src/date.lo ext/pdo_sqlite/sqlite/src/delete.lo ext/pdo_sqlite/sqlite/src/expr.lo ext/pdo_sqlite/sqlite/src/func.lo ext/pdo_sqlite/sqlite/src/hash.lo ext/pdo_sqlite/sqlite/src/insert.lo ext/pdo_sqlite/sqlite/src/legacy.lo ext/pdo_sqlite/sqlite/src/main.lo ext/pdo_sqlite/sqlite/src/os_unix.lo ext/pdo_sqlite/sqlite/src/os_win.lo ext/pdo_sqlite/sqlite/src/os.lo ext/pdo_sqlite/sqlite/src/pager.lo ext/pdo_sqlite/sqlite/src/pragma.lo ext/pdo_sqlite/sqlite/src/prepare.lo ext/pdo_sqlite/sqlite/src/printf.lo ext/pdo_sqlite/sqlite/src/random.lo ext/pdo_sqlite/sqlite/src/select.lo ext/pdo_sqlite/sqlite/src/table.lo ext/pdo_sqlite/sqlite/src/tokenize.lo ext/pdo_sqlite/sqlite/src/analyze.lo ext/pdo_sqlite/sqlite/src/complete.lo ext/pdo_sqlite/sqlite/src/trigger.lo ext/pdo_sqlite/sqlite/src/update.lo ext/pdo_sqlite/sqlite/src/utf.lo ext/pdo_sqlite/sqlite/src/util.lo ext/pdo_sqlite/sqlite/src/vacuum.lo ext/pdo_sqlite/sqlite/src/vdbeapi.lo ext/pdo_sqlite/sqlite/src/vdbeaux.lo ext/pdo_sqlite/sqlite/src/vdbe.lo ext/pdo_sqlite/sqlite/src/vdbemem.lo ext/pdo_sqlite/sqlite/src/where.lo ext/pdo_sqlite/sqlite/src/parse.lo ext/pdo_sqlite/sqlite/src/opcodes.lo ext/pdo_sqlite/sqlite/src/alter.lo ext/pdo_sqlite/sqlite/src/vdbefifo.lo ext/pdo_sqlite/sqlite/src/vtab.lo ext/pdo_sqlite/sqlite/src/loadext.lo ext/posix/posix.lo ext/reflection/php_reflection.lo ext/session/session.lo ext/session/mod_files.lo ext/session/mod_mm.lo ext/session/mod_user.lo ext/simplexml/simplexml.lo ext/spl/php_spl.lo ext/spl/spl_functions.lo ext/spl/spl_engine.lo ext/spl/spl_iterators.lo ext/spl/spl_array.lo ext/spl/spl_directory.lo ext/spl/spl_sxe.lo ext/spl/spl_exceptions.lo ext/spl/spl_observer.lo ext/sqlite/sqlite.lo ext/sqlite/sess_sqlite.lo ext/sqlite/pdo_sqlite2.lo ext/sqlite/libsqlite/src/opcodes.lo ext/sqlite/libsqlite/src/parse.lo ext/sqlite/libsqlite/src/encode.lo ext/sqlite/libsqlite/src/auth.lo ext/sqlite/libsqlite/src/btree.lo ext/sqlite/libsqlite/src/build.lo ext/sqlite/libsqlite/src/delete.lo ext/sqlite/libsqlite/src/expr.lo ext/sqlite/libsqlite/src/func.lo ext/sqlite/libsqlite/src/hash.lo ext/sqlite/libsqlite/src/insert.lo ext/sqlite/libsqlite/src/main.lo ext/sqlite/libsqlite/src/os.lo ext/sqlite/libsqlite/src/pager.lo ext/sqlite/libsqlite/src/printf.lo ext/sqlite/libsqlite/src/random.lo ext/sqlite/libsqlite/src/select.lo ext/sqlite/libsqlite/src/table.lo ext/sqlite/libsqlite/src/tokenize.lo ext/sqlite/libsqlite/src/update.lo ext/sqlite/libsqlite/src/util.lo ext/sqlite/libsqlite/src/vdbe.lo ext/sqlite/libsqlite/src/attach.lo ext/sqlite/libsqlite/src/btree_rb.lo ext/sqlite/libsqlite/src/pragma.lo ext/sqlite/libsqlite/src/vacuum.lo ext/sqlite/libsqlite/src/copy.lo ext/sqlite/libsqlite/src/vdbeaux.lo ext/sqlite/libsqlite/src/date.lo ext/sqlite/libsqlite/src/where.lo ext/sqlite/libsqlite/src/trigger.lo regex/regcomp.lo regex/regexec.lo regex/regerror.lo regex/regfree.lo ext/standard/array.lo ext/standard/base64.lo ext/standard/basic_functions.lo ext/standard/browscap.lo ext/standard/crc32.lo ext/standard/crypt.lo ext/standard/cyr_convert.lo ext/standard/datetime.lo ext/standard/dir.lo ext/standard/dl.lo ext/standard/dns.lo ext/standard/exec.lo ext/standard/file.lo ext/standard/filestat.lo ext/standard/flock_compat.lo ext/standard/formatted_print.lo ext/standard/fsock.lo ext/standard/head.lo ext/standard/html.lo ext/standard/image.lo ext/standard/info.lo ext/standard/iptc.lo ext/standard/lcg.lo ext/standard/link.lo ext/standard/mail.lo ext/standard/math.lo ext/standard/md5.lo ext/standard/metaphone.lo ext/standard/microtime.lo ext/standard/pack.lo ext/standard/pageinfo.lo ext/standard/quot_print.lo ext/standard/rand.lo ext/standard/reg.lo ext/standard/soundex.lo ext/standard/string.lo ext/standard/scanf.lo ext/standard/syslog.lo ext/standard/type.lo ext/standard/uniqid.lo ext/standard/url.lo ext/standard/url_scanner.lo ext/standard/var.lo ext/standard/versioning.lo ext/standard/assert.lo ext/standard/strnatcmp.lo ext/standard/levenshtein.lo ext/standard/incomplete_class.lo ext/standard/url_scanner_ex.lo ext/standard/ftp_fopen_wrapper.lo ext/standard/http_fopen_wrapper.lo ext/standard/php_fopen_wrapper.lo ext/standard/credits.lo ext/standard/css.lo ext/standard/var_unserializer.lo ext/standard/ftok.lo ext/standard/sha1.lo ext/standard/user_filters.lo ext/standard/uuencode.lo ext/standard/filters.lo ext/standard/proc_open.lo ext/standard/streamsfuncs.lo ext/standard/http.lo ext/tokenizer/tokenizer.lo ext/tokenizer/tokenizer_data.lo ext/xml/xml.lo ext/xml/compat.lo ext/xmlreader/php_xmlreader.lo ext/xmlwriter/php_xmlwriter.lo TSRM/TSRM.lo TSRM/tsrm_strtok_r.lo TSRM/tsrm_virtual_cwd.lo main/main.lo main/snprintf.lo main/spprintf.lo main/php_sprintf.lo main/safe_mode.lo main/fopen_wrappers.lo main/alloca.lo main/php_scandir.lo main/php_ini.lo main/SAPI.lo main/rfc1867.lo main/php_content_types.lo main/strlcpy.lo main/strlcat.lo main/mergesort.lo main/reentrancy.lo main/php_variables.lo main/php_ticks.lo main/network.lo main/php_open_temporary_file.lo main/php_logos.lo main/output.lo main/streams/streams.lo main/streams/cast.lo main/streams/memory.lo main/streams/filter.lo main/streams/plain_wrapper.lo main/streams/userspace.lo main/streams/transports.lo main/streams/xp_socket.lo main/streams/mmap.lo Zend/zend_language_parser.lo Zend/zend_language_scanner.lo Zend/zend_ini_parser.lo Zend/zend_ini_scanner.lo Zend/zend_alloc.lo Zend/zend_compile.lo Zend/zend_constants.lo Zend/zend_dynamic_array.lo Zend/zend_execute_API.lo Zend/zend_highlight.lo Zend/zend_llist.lo Zend/zend_opcode.lo Zend/zend_operators.lo Zend/zend_ptr_stack.lo Zend/zend_stack.lo Zend/zend_variables.lo Zend/zend.lo Zend/zend_API.lo Zend/zend_extensions.lo Zend/zend_hash.lo Zend/zend_list.lo Zend/zend_indent.lo Zend/zend_builtin_functions.lo Zend/zend_sprintf.lo Zend/zend_ini.lo Zend/zend_qsort.lo Zend/zend_multibyte.lo Zend/zend_ts_hash.lo Zend/zend_stream.lo Zend/zend_iterators.lo Zend/zend_interfaces.lo Zend/zend_exceptions.lo Zend/zend_strtod.lo Zend/zend_objects.lo Zend/zend_object_handlers.lo Zend/zend_objects_API.lo Zend/zend_default_classes.lo Zend/zend_execute.lo sapi/apache2handler/mod_php5.lo sapi/apache2handler/sapi_apache2.lo sapi/apache2handler/apache_config.lo sapi/apache2handler/php_functions.lo main/internal_functions.lo -lcrypt -lcrypt -lrt -lz -lresolv -lm -lnsl -lxml2 -lz -lm -lxml2 -lz -lm -lxml2 -lz -lm -lcrypt -lxml2 -lz -lm -lxml2 -lz -lm -lxml2 -lz -lm -lcrypt -o libphp5.la
icc: command line warning #10156: ignoring option '-s'; no argument required
TimP
Black Belt
You didn't show any error message, unless the warning means there is an option which was misread. -s normally would instruct ld to strip symbols, with the objective either of reducing size or impeding debugging.
carlseamicro_com
Quoting - tim18
My bad... I missed the following two lines while copy-paste...
ld: libphp5.so: No such file: No such file or directory
make: *** [libphp5.la] Error 1
carlseamicro_com
OK. I found the problem and the problem is not related to icc compiler... I am updating this thread if someone else is seeing similar issues...
When running PHP ./configure with enviornmental variable CC set to icc and threading enabled (--enable-maintainer-zts), PHP creates a new file, meta_ccld. My meta_ccld file looks like
#! /bin/shell
exec /opt/intel/Compiler/11.0/083/bin/ia32/icc -pthread $@
Later in the configure process, meta_ccld, instead of icc, is used to check for compiler option to produce PIC. Because configure does not know about meta_ccld as a compiler, it does not set up correct values for lt_prog_compiler_wl, lt_prog_compiler_pic and lt_prog_compiler_static.
Since I am only doing this compile for icc, I copied and pasted the code for icc to meta_ccld for setting "-Wl," "-fPIC" and "-static". Now, compile works correctly and libphp5.a and libphp5.so are created.
Thanks for your help!!
JenniferJ
Thanks for sharing your finding!
