I've reduced your code to this small example which shows the problem:
template
struct CBase
void trace(int);
template< class T >
struct C : public CBase
template< int codim >
void trace()
trace(4);
using CBase
int main() {
C
c.trace<1>();
return 0;
As a workaround I thinkyou can move the using declaration of traceto somewhere before the call.
That seems to prevent the internal error. In the meantime, we're working on a fix....
Judy
In any case, an internal error on a current release is a reportable bug, so you could submit the file which provokes it in a problem report on https://premier.intel.com (open a support account at https://registrationcenter.intel.com, if you haven't done so already).
Hello tim18,
thanks for your reply. I filed that bug report now, so I guess this topic may be considered closed. For the record, icpc -V gives:
Intel C++ Compiler Professional for applications running on IA-32, Version 11.1 Build 20090511 Package ID: l_cproc_p_11.1.038
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
30 DAY EVALUATION LICENSE
icpc: NOTE: The evaluation period for this product ends on 2-oct-2009 UTC.
Leonard.
I just noticed an issue filed in Premier, and I'll respond there on this, just FYI
-thanks,
Kittur
I've reproduced the issue generating a smaller test case that reproduces the internal error when compiling icpc.
Also, I"ve filed the issue with our developers and will update this post as soon as there's an update on this issue, just FYI.
BTW, the option -stdc++0x isvalid in icpc, and enables preliminary support for some C++0x features (like Lambda, auto etc). Once, this internal error issue is resolved, we can then attempt to build your application and see if there are any problems or issues encountered thereof.
-regards,
Kittur
-regards,
Kittur
template
struct CBase
void trace(int);
template< class T >
void trace()
trace(4);
using CBase
int main() {
C
c.trace<1>();
return 0;
Judy
This issue is fixed in the latest version of the compiler that's released. You can download the Intel Composer XE update 1 release from the https://registrationcenter.intel.com/RegCenter/
-regards,
Kittur
