Hi I am using intel compilers for netcdf-3.6.3 installation. While installing this software i am getting the following error. Any body can tell me how to solve this problem
configure:3588: checking for C compiler version
configure:3596: icc --version >&5
icc: error #10149: option '-cxxlib-gcc' not supported with the current installed GCC
configure:3600: $? = 1
configure:3607: icc -v >&5
Version 11.0
configure:3611: $? = 0
configure:3618: icc -V >&5
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0 Build 20081105 Package ID: l_cproc_p_11.0.074
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
configure:3622: $? = 0
configure:3645: checking for C compiler default output file name
configure:3667: icc conftest.c >&5
configure:3671: $? = 1
configure:3709: result:
configure: failed program was:
yajivbs
Version 11.0
yajivbs
I guess it means you must remove the option -cxxlib-gcc from the build. There has never been an option in this respect for icpc Intel64. It meant use the libstdc++ from the active g++, for past versions of icc which provided a Dinkumware STL, in cases where people wanted to use an ancient gcc which had no libstdc++ resembling the standard ones.
Read the note about netcdf and icc, and show us your g++ -print-search-dirs, if you have further trouble.
Quoting - tim18
Hi
Thank you very much for your reply. How to remove -cxxlib-gcc from build.
Quoting - yajivbs
Hi
Quoting - tim18
That option must be coming from your netcdf configure or makefiles. So get out grep and your text editor.
Hi
This is my g++ -print-search-dirs
[root@vijay ~]# g++ -print-search-dirs
install: /usr/lib/gcc/x86_64-redhat-linux/3.4.6/
programs: =/usr/libexec/gcc/x86_64-redhat-linux/3.4.6/:/usr/libexec/gcc/x86_64-redhat-linux/3.4.6/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/:/usr/libexec/gcc/x86_64-redhat-linux/3.4.6/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../x86_64-redhat-linux/bin/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../x86_64-redhat-linux/bin/
libraries: =/usr/lib/gcc/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../x86_64-redhat-linux/lib/x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../x86_64-redhat-linux/lib/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../x86_64-redhat-linux/3.4.6/:/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../:/lib/x86_64-redhat-linux/3.4.6/:/lib/:/usr/lib/x86_64-redhat-linux/3.4.6/:/usr/lib/
[root@vijay ~]# rpm -qa | grep gcc
gcc-4.1.1-52.el5
compat-gcc-34-g77-3.4.6-4
libgcc-4.1.1-52.el5
libgcc-4.1.1-52.el5
compat-gcc-34-3.4.6-4
compat-gcc-34-c++-3.4.6-4
[root@vijay ~]#
How to solve that icc problem
Quoting - yajivbs
Hi
gcc-4.1.1-52.el5
libgcc-4.1.1-52.el5
libgcc-4.1.1-52.el5
[root@vijay ~]#
You have find -cxxlib-gcc option string and remove it as this is not supported in icc 11.0.
Quoting - Om Sachan (Intel)
Hello Sir,
Can you please give me the steps to remove -cxxlib-gcc option?
I'm also getting error for using gcc 4.2 with icc 11.0
Thanking you,
Dny
I do not have expertise in netcdf-3.6.3 build. The option is coming from some makefile or configure.
Is g++ already installed?
I receive this message from a system without g++.
Type:
$ which g++
I read too that this message can be generated when using diferent versions of gcc and g++.
Type:
$ which g++
Quoting - viniciushax
Type:
$ which g++
Type:
$ which g++
Quoting - yajivbs
Version 11.0
yajivbs
Version 11.0
yajivbs
The KB here: http://software.intel.com/en-us/articles/cdiag10149/ and the discussion here: http://software.intel.com/en-us/forums/showthread.php?t=65784 may help.
icc -gcc-name=gcc34
OR for icpc
icpc -gxx-name=g++34
I use this for solve icc problem
Also check your icc.cfg and iccvars.shfiles. May be someone added it there? And check to see that "icc" isn't aliased to "icc -cxxlib-gcc". The icc.cfg you are usingshould be in
Judy
