Intel® C++ Compiler
icc: error #10236: File not found: '(ICC)'
andyluoms
I use Intel? C++ Studio XE 2011 for Linux* OS to compile Linux Kernel (version:2.6.32.12-0.7) in intel64 ,I get the following error:
icc: error #10236: File not found:  '12.0.0'
icc: error #10236: File not found:  '20101006'
at last
make[1]: *** [kdb/kdbmain.o] Error 1
make: *** [kdb] Error 2
the version is : icc (ICC) 12.0.0 20101006
Any ideas on how I can remedy this ?
Thanks!
Andy
Sukruth_H_Intel
Hi, Could you please let me know the command line and the options that you used for the build. Could you also confirm, that this isssue can been seen with the normal compile and run of simple programs lets say "Hello world" using ICC compiler? Regards, Sukruth H V
andyluoms
Use the command line: make CC=kicc HOSTCC=kicc LD=xild AR=xiar V=1 bzImage to make image. the kicc follow: ########################kicc #!/bin/sh #-------------------------------------------------------- # Kernel icc # This is a wraper around icc to be compatible with gcc for kernel build #-------------------------------------------------------- ARGS=$@ #Add "-gcc" in the prevention of icc.cfg have "-no-gcc" ICCARGS="-fno-builtin -gcc" if [ -z "$ICC" ];then ICC=icc fi if [ -z "$GCC"];then GCC=gcc fi for ARG in $@ do case $ARG in -fno-stack-protector ) ICCARGS="$ICCARGS -fno-stack-security-check" ;; #-march=* ) # ICCARGS="$ICCARGS -xN -axN" # ;; -O2| -O3) ICCARGS="$ICCARGS -O2" ;; -v ) $ICC --version 2>&1 | grep "icc" exit 0 ;; */boot/* ) $GCC $ARGS exit $? ;; #ignore these gcc options -fno-unit-at-a-time | -fno-inline | -g | -gstabs | -maccumulate-outgoing-args|-mno-3dnow|-mno-mmx|-mno-sse|-mno-sse2|-mpreferred-stack-boundary=2|-msoft-float|-nostdinc|-pipe|-Wall|-Wno-pointer-sign) ;; *) ICCARGS="$ICCARGS $ARG" ;; esac done $ICC $ICCARGS exit $? EOF Thanks! Andy
andyluoms
Other question,I setup icc in virtual machine,run icc test.c,get the follow error: ": internal error: backend signals icc: error #10106: Fatal error in /opt/intel/composer_xe_2013.1.117/bin/intel64/mcpcom, terminated by segmentation violation compilation aborted for /home/lsy/test.c (code 1) Any ideas? Thanks! Andy
Sukruth_H_Intel
Hi, Could you please let me know what is the content of test.c? Also can you let me know the OS you have installed on the Virtual machine? Did you see any error while installing the Composer XE package? Regards, Sukruth H V
andyluoms
Hi, The test.c is simple : int main(void) { printf("hello icc!\n"); return 0; } The same version of icc installed on Virtual machine and Physical machine,but on the Physical machine has no the follow errors: ############################## ": internal error: backend signals icc: error #10106: Fatal error in /opt/intel/composer_xe_2013.1.117/bin/intel64/mcpcom, terminated by segmentation violation compilation aborted for /home/lsy/test.c (code 1) ############################## OS version: SUSE Linux Enterprise Server 11 (x86_64) VERSION = 11 PATCHLEVEL = 1 Linux ctucipjslx032 2.6.32.12-0.7-default #1 SMP 2010-05-20 11:14:20 +0200 x86_64 Intel(R) Xeon(R) CPU X5670 @ 2.93GHz GenuineIntel GNU/Linux Thanks! Andy
Sukruth_H_Intel
Hi, I see that the support for the SUS Linux Enterprise Server 11 has been dropped. Please see the following link about the OS not supported http://software.intel.com/en-us/articles/intel-c-composer-xe-2013-for-linux-initial-release. Also i suggest you to check carefully, Whether you will see any errors while installing the Compiler on the OS installed on Virtual machine. Regards, Sukruth H V
andyluoms
Where can I get the documents for compile linux kernel using icc? Thanks! Andy
TimP
According to that reference, SLES11 SP2 is supported by current icc. Earlier SP is not supported, although it may work to some extent.
