Hi ,
I was evaluating trial version of "parallel_studio_xe_2016_composer_edition_for_cpp_update2 (1).tgz". I installed the package as root in defualt location - "/opt/intel"
I have sourced the env by invoking - source /opt/intel/compilers_and_libraries_2016.2.181/linux/bin/compilervars.csh intel64
But i am getting the error "icc: error #10295: error generating temporary file name, check disk space and permissions"
Please help !
Anchal
Hi Anchal,
The probable cause is that your /tmp and /home directory may be out of disk space. Check to ensure there's sufficient storage space for all the generation of files by the installer. Let me know if that resolves your issue, thanks.
_Kittur
Hi ,
Disk space is as follows /tmp folder :
Filesystem Size Used Avail Use% Mounted on
/dev/sda3 46G 33G 11G 76% /
Do not see a problem there.
Anchal
If by chance you are trying to build one of the sample files, then you should be aware that the sample files may be located in a read only folder. IOW copy these out of the distribution folder into your workspace folder, then build from there.
Jim Dempsey
Thanks Jim, that could be the reason as well (installed as root and may be running as user in those directories having root permission read/execute permissions only).
Hi Anchal,
Can you check the above and if you're running samples ensure you've permissions to execute and write as well?
Kittur
