Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
icc: error #10310
Jump to solution
Recently I downloaded free evaluation intel compiler and installed it on Ubuntu 9, installation was sucessful, however, when I ran the compiler, I got the following error,
ubuntu01:~$ /opt/intel/Compiler/11.1/046/bin/ia32/icc
icc: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 2). Trusted Storage based license could
How to solve this problem? Thank!
Accepted Solutions
Highlighted
Black Belt
Could you please try:
source /opt/intel/Compiler/11.1/046/bin/ia32/iccvars_ia32.sh
and then type icc to see if the problem is resolved.
-Yang
In fact, in case the licensing depends on an environment variable setting which ought to be in the script, this looks like the right idea. However, the normal way, source /opt/intel/Compiler.11.1/046/bin/iccvars.sh ia32, should be preferred.
Highlighted
Quoting - wwzhdo
-Yang
Highlighted
Black Belt
-Yang
Highlighted
Quoting - tim18
Thanks! it solved the problem. I should run this script right after I findish installation.
Another question, looke like icc needs libstdc++.so.5
error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory.
I have libstdc++.so.6 installed on this ubuntu 9 machine? Shall I install libstdc++.so.6 or is there any other way to solve it?
Highlighted
Black Belt
The best way is to add libstdc++.so.5, if it's available as an option for the distro. If not, there's a chance a symlink may work. Ron Green has a guide for Ubuntu installation at the top of the Fortran linux forum:
http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu/
