I'm getting same error for icc .
icc MatMul2D.cpp
icc: error #10149: option '-cxxlib-gcc' not supported with the current installed GCC
Following are my gcc and g++ version , but the versions are same so who to fix this error.
gcc --version
gcc (GCC) 4.2.4
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0 Build 20081105 Package ID: l_cproc_p_11.0.074
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
could anyone tell me who to resolve this error?
Thanking you,
Digambar
icc MatMul2D.cpp
gcc --version
gcc (GCC) 4.2.4
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Thanking you,
Digambar
Quoting - Dny
icc MatMul2D.cpp
gcc --version
gcc (GCC) 4.2.4
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Thanking you,
Digambar
icc MatMul2D.cpp
gcc --version
gcc (GCC) 4.2.4
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Thanking you,
Digambar
Hi
Use this command
gcc -v
You can see if you having all options builded in GNU compiler
Example command resulting
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 4.3.2-1.1' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --enable-targets=all --enable-cld --enable-checking=release --build=i486-linux-gnu --host=i486-linux-gnu --target=i486-linux-gnu
Thread model: posix
gcc version 4.3.2 (Debian 4.3.2-1.1)
Best regards
Quoting - bustaf
Hi
Use this command
gcc -v
Thread model: posix
Best regards
Thanks for your reoly ,
The output of gccc -v is following
Target: x86_64-unknown-linux-gnu
Configured with: ./configure --prefix=/app/gcc4.2/
Thread model: posix
gcc version 4.2.4
I think it may be issue of compatibility of icc 11.0.074 and gcc 4.2.
Dny
Quoting - Dny
We have seen this message provoked at installation by problems with the g++ installation. You might argue that it's a bug when this message comes out as a result of a different problem.
If your project doesn't build correctly with g++, on account of such a problem, you must correct that.
Quoting - Dny
icc MatMul2D.cpp
gcc --version
gcc (GCC) 4.2.4
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Thanking you,
Digambar
icc MatMul2D.cpp
gcc --version
gcc (GCC) 4.2.4
g++ --version
g++ (GCC) 4.2.4
ICC version
icc -V
Thanking you,
Digambar
Your GNU C & C++ compilers haven't been installed properly. Try installing fresh GNU Compiler Toolchain (GCC - 4.4, Binutils-2.18.50.0.9, & Glibc-2.7)
Please follow below steps -
1. Install first MPFR (http://www.mpfr.org/)followed byGMP (http://gmplib.org/).
2. Try Installing Binutils as - http://www.kernel.org/pub/linux/devel/binutils/ . While configuring Binutils, try referring PATH of MPFR & GMP both with Binutils installation.
3. Install GNU compilers (v4.4) from http://gcc.gnu.org/releases.html . Do include MPFR & GMP too.
4. Related to glibc either you can install or refer the link in /usr/lib64 folder forglibc libraries.
Follow above properly, your problem will be 100% resolved. Above successful GNU Toolchain installation shouldn't take more than 1.0 - 1.5 hours.
~BR
Mukkaysh Srivastav
Quoting - srimks
I haven't had much luck with binutils 2.18.50. If your distro doesn't provide a satisfactory one, I would prefer a current version from that site.
I doubt that glibc-2.7 is a worth while path, unless it is supported by your distro. If glibc-2.5 works with your g++, it should be no problem with icpc. I agree that 2.6 ought to help with upgrading gcc beyond what your distro supplies, but that shouldn't be necessary for icpc.
Quoting - tim18
I agree that the message may show a problem with the active g++ installation.
~BR
