I have made test Debian Lenny (5) gsl lib with GNU compiler origin default: is:
gcc -v
Target: x86_64-linux-gnu
Configur avec: ../src/configure -v --with-pkgversion='Debian 4.3.2-1.1' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --enable-cld --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Modle de thread: posix
gcc version 4.3.2 (Debian 4.3.2-1.1)
Before to use Intel compiler you must build the source GNU to evaluate if not other problem exist.
download gsl-1.14
For that you can result all tests (GNU GCC) without fault require you must using use first this simple syntax not really optimized (just change core2 for your processors)
CFLAGS="-O2 -m64 -march=core2 -mtune=core2 -Wpointer-arith -fno-strict-aliasing ";export CFLAGS
make distclean
./configure
make --jobs=4
make check
Result: I have all test passed ok GNU
For Icc compiler also all test passed ok , use the flag same is given after.
Compiler version is the last...
debian:/usr/src/download/gsl-1.14# icc -V
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
LANG=C; export LANG
CC="/opt/intel/Compiler/11.1/072/bin/intel64/icc"; export CC
LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/072/lib/intel64;export LD_LIBRARY_PATH;export LD_LIBRARY_PATH
CFLAGS="-O2 -m64 -mieee-fp -march=core2 -mtune=core2 -Wpointer-arith -fno-strict-aliasing "; export CFLAGS
make distclean
./configure
make --jobs=4
make check (make check > log 2>&1)
I have all test passed ok Icc Intel compiler
If i have time i see after, how would be make better for improve (fast or other ???).
Good luck
make check returns an error with
Making check in ode-initval
make[1]: Entering directory `/home/kirill/tmp/gsltry/gsl-1.14/ode-initval'
make test
make[2]: Entering directory `/home/kirill/tmp/gsltry/gsl-1.14/ode-initval'
make[2]: `test' is up to date.
make[2]: Leaving directory `/home/kirill/tmp/gsltry/gsl-1.14/ode-initval'
make check-TESTS
gsl: lu.c:147: ERROR: matrix is singular
Default GSL error handler invoked.
/bin/sh: line 5: 23595 Aborted ${dir}$tst
FAIL: test
1 of 1 test failed
An older thread that you might find useful.
http://origin-software.intel.com/en-us/forums/showthread.php?t=58135
the problem with ode-initval still comes up
intels-mac-pro:gsl-1.14 ale$ cat l.txt
export CC=icc
export CXX=icpc
export CFLAGS="-arch i386 -fp-model double"
export LDFLAGS="-arch i386"
./configure --prefix=/opt/gsl_an --disable-shared --disable-dependency-tracking
Making check in ode-initival
make test
icc -DHAVE_CONFIG_H -I. -I.. -I.. -arch i386 -fp-model double -c test.c
/bin/sh ../libtool --tag=CC --mode=link icc -arch i386 -fp-model double -arch i386 -o test test.o libgslodeiv.la ../linalg/libgsllinalg.la ../blas/libgslblas.la ../cblas/libgslcblas.la ../matrix/libgslmatrix.la ../permutation/libgslpermutation.la ../vector/libgslvector.la ../block/libgslblock.la ../complex/libgslcomplex.la ../ieee-utils/libgslieeeutils.la ../err/libgslerr.la ../test/libgsltest.la ../sys/libgslsys.la ../utils/libutils.la -lm
libtool: link: icc -arch i386 -fp-model double -arch i386 -o test test.o ./.libs/libgslodeiv.a ../linalg/.libs/libgsllinalg.a ../blas/.libs/libgslblas.a ../cblas/.libs/libgslcblas.a ../matrix/.libs/libgslmatrix.a ../permutation/.libs/libgslpermutation.a ../vector/.libs/libgslvector.a ../block/.libs/libgslblock.a ../complex/.libs/libgslcomplex.a ../ieee-utils/.libs/libgslieeeutils.a ../err/.libs/libgslerr.a ../test/.libs/libgsltest.a ../sys/.libs/libgslsys.a ../utils/.libs/libutils.a -lm
make check-TESTS
Completed [3509/3509]
PASS: test
1 test passed
./configure FC=ifort CC=icc CFLAGS="-m32 -fp-model double" LDFLAGS="-m32"
./configure FC=ifort CC=icc CFLAGS="-m32 -fp-model double" LDFLAGS="-m32" --disable-shared --disable-dependency-tracking
linux uses -m32 instead of -arch i386 and -m64 instead of -arch x86_64
***i got errors while configuring :
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for a sed that does not truncate output... /bin/sed
checking whether make sets $(MAKE)... (cached) yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... icc
checking whether the C compiler works... no
configure: error: in `/home/kirill/tmp/gsltry/gsl-1.14':
configure: error: C compiler cannot create executables
See `config.log' for more details.
***from config.log:
98 configure:3563: result: no
99 configure: failed program was:
100 | /* confdefs.h */
101 | #define PACKAGE_NAME "gsl"
102 | #define PACKAGE_TARNAME "gsl"
103 | #define PACKAGE_VERSION "1.14"
104 | #define PACKAGE_STRING "gsl 1.14"
105 | #define PACKAGE_BUGREPORT ""
106 | #define PACKAGE_URL ""
107 | #define PACKAGE "gsl"
108 | #define VERSION "1.14"
109 | #define RELEASED /**/
110 | /* end confdefs.h. */
111 |
112 | int
113 | main ()
114 | {
115 |
116 | ;
117 | return 0;
118 | }
119 configure:3568: error: in `/home/kirill/tmp/gsltry/gsl-1.14':
120 configure:3572: error: C compiler cannot create executables
121 See `config.log' for more details.
configure worked with -m64 but gave the same ode-initval error as before
why do you use -arch i386? isn't mac pro x86_64?
gcc -v
download gsl-1.14
make distclean
./configure
make --jobs=4
make check
LANG=C; export LANG
make distclean
./configure
make --jobs=4
Good luck
thank you for your time and help
--Kirill
With flag -ipo also all test passed ok
Use same:
make distclean
LANG=C; export LANG
AR="/opt/intel/Compiler/11.1/072/bin/intel64/xiar";export AR
CFLAGS="-O2 -m64 -mieee-fp -ipo -override-limits -march=core2 -mtune=core2 -Wpointer-arith -fno-strict-aliasing "; export CFLAGS
./configure
or
./configure --disable-shared
Use (DSO) for call if it can work .. i think maybe probably better.
Difficult to find nice tune with this machine used ,is too small not appropriated this type source , also i
have football cup (TV) shared same desktop in other terminal and result could be not signifiant
I have read that to one month Intel make promotion i7 950 decreased price almost 50% ,
but unfortunately world cup would be already ended...
