Hi!
while compiling linux kernel 2.6.14.6:
icc -m32 -Wp,-MD,init/.do_mounts.o.d -nostdinc -isystem /usr/lib/gcc-lib/i486-slackware-linux/3.3.4/include -D__KERNEL__ -Iinclude -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -pipe -msoft-float -mpreferred-stack-boundary=2 -fno-unit-at-a-time -march=i686 -mtune=pentium2 -Iinclude/asm-i386/mach-default -Wdeclaration-after-statement -Wno-pointer-sign -DKBUILD_BASENAME=do_mounts -DKBUILD_MODNAME=mounts -c -o init/do_mounts.o init/do_mounts.c
[some warnings]
init/do_mounts.c(342): (col. 2)internal error: 0_1733
compilation aborted for init/do_mounts.c (code 4)
make[1]: *** [init/do_mounts.o] Error 4
make: *** [init] Error 2
where line 342 is: va_end(args);
is this a collision error or what does it mean?
TIA,
jonathan
[some warnings]
TIA,
jonathan
I'm not sure what you mean by collision error.
The internal error indicates that the compiler crashed while attempting to compile. I suggest creating a preprocessed file that reproduces the problem and submitting the issue to premier support as a bug report. This will be the fastest path to having our team look at and see what can be done.
Max
Those warnings you removed where the interesting ones. It indicated a problem with va_start, va_arg and va_end. I know what is causing this (the -isystem /path/to/some/gcc/specific/header/directory/) but I am not sure if it is ok to just leave it out. Go ahead and remove it from the command line and then report back. You probably have to remove them from the Makefile and start from scratch.
Hope this helps,
Otto
Topic Options
