Intel® C++ Compiler
icc: noexcept in secondary thread loses stack on throw on linux
Teijo_H_
Hi, I came across an issue with the ICC compiler (2015.1.133) on Linux when using throw in a secondary thread that was declared with noexcept:
#include <thread>
void f1() {
      throw 1;
void f2() noexcept {
      f1();
int main( int argc, char **argv ) {
      std::thread t(f2);
      t.join();
      return 0;
If you run it through icc & gdb (Kubuntu 12.04 & 16.04), you see an incomplete and incorrect stack trace:
# icc -v
icc version 15.0.1 (gcc version 4.6.0 compatibility)
# icc -g -pthread -std=gnu++0x -o test test2.cc
# gdb test
(gdb) r
(gdb) bt
#0  0x00007ffff70150d5 in __GI_raise (sig=) at ../nptl/sysdeps/unix/sysv/linux/raise.c:64
#1  0x00007ffff701883b in __GI_abort () at abort.c:91
#2  0x00007ffff783316d in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3  0x00007ffff78311d6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4  0x00007ffff7831221 in std::terminate() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5  0x00007ffff7831236 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6  0x00007ffff7830e92 in __cxa_call_unexpected () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#7  0x0000000000400f15 in f2 () at test.cc:7
If you run it through gcc & gdb (Kubuntu 12.04 & 16.04), you see the complete and correct stack trace:
# gcc -v
gcc version 4.6.4 (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04)
# g++ -g -pthread -std=c++0x -o test test2.cc
# gdb test
(gdb) r
(gdb) bt
#0  0x00007ffff73110d5 in __GI_raise (sig=) at ../nptl/sysdeps/unix/sysv/linux/raise.c:64
#1  0x00007ffff731483b in __GI_abort () at abort.c:91
#2  0x00007ffff7b2f16d in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3  0x00007ffff7b2d1d6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4  0x00007ffff7b2c2c9 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5  0x00007ffff7b2ca2b in __gxx_personality_v0 () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6  0x00007ffff78c7013 in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#7  0x00007ffff78c739b in _Unwind_RaiseException () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#8  0x00007ffff7b2d42b in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#9  0x0000000000400d4a in f1 () at test.cc:4
#10 0x0000000000400d53 in f2 () at test.cc:8
Viet_H_Intel
I am having error when compiling your test case.
vahoang@orcsle100:/tmp$ gcc -g -pthread -std=gnu++0x -o test c.cc
c.cc:6: error: expected initializer before ânoexceptâ
c.cc: In function âint main(int, char**)â:
c.cc:11: error: âf2â was not declared in this scope
vahoang@orcsle100:/tmp$ cat c.cc
#include <thread>
void f1() {
      throw 1;
      f1();
      std::thread t(f2);
      t.join();
      return 0;
Viet Hoang
Teijo_H_
Please use g++ instead of gcc and use version 4.6 or higher.
Viet_H_Intel
It looks like a bug to me. Can you please submit a ticket at https://supporttickets.intel.com/?
Viet Hoang
