Intel® C++ Compiler
7956 Discussions
icc reports "Requires 'install path' setting gathered from 'gcc'"
Hao_Z_
# what happened
sample code("main.c"):
int main(){}
when run `icc main.c`, it reports:
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'install path' setting gathered from 'gcc'
# environments
arch linux
Linux zhanghao 4.14.15-1-ARCH #1 SMP PREEMPT Tue Jan 23 21:49:25 UTC 2018 x86_64 GNU/Linux
gcc 7.3
gcc (GCC) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
icc from `parallel_studio_xe_2018_update1_cluster_edition`
# some details
`strace -f icc ./main.c` result is in attach
Viet_H_Intel
It seems to me that the GCC version you have is unsupported in ICC 18.0.
Viet
jperaltac
What is the GCC version supported by ICC 18.0? I have the same issue with GCC 6.3
Thanks in advance for your help.
JP
Hao_Z_
I find out where is wrong now ...
when icc compile source, icc will call `gcc --print-search-dirs -m64`
icc expect it output `install: /usr/lib/`
but in my PC, I set environment variable `LC_MESSAGES=zh_CN.UTF-8`
so, its output is `安装:/usr/lib/...` indeed.
then icc cannot understand it
to solve it, run something like `export LC_MESSAGES=POSIX` before run icc
Viet_H_Intel
Hao_Z_
this is not because of incompatible gcc version, but wrong locale environtment setting.
Hao_Z_
As you see, even with correct gcc version, if i set locale to other language, icc won't work still ``` ~  env -i bash -rcfile /dev/null bash-4.2$ gcc --version gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16) Copyright (C) 2015 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. bash-4.2$ /opt/intel/compilers_and_libraries_2018.1.163/linux/bin/intel64/icc --version icc (ICC) 18.0.1 20171018 Copyright (C) 1985-2017 Intel Corporation. All rights reserved. bash-4.2$ cat ./main.c #include int main(){ printf("Hello World\n"); return 0; } bash-4.2$ LC_MESSAGES=zh_CN.UTF-8 /opt/intel/compilers_and_libraries_2018.1.163/linux/bin/intel64/icc ./main.c icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'install path' setting gathered from 'gcc' bash-4.2$ locale LANG= LC_CTYPE="POSIX" LC_NUMERIC="POSIX" LC_TIME="POSIX" LC_COLLATE="POSIX" LC_MONETARY="POSIX" LC_MESSAGES="POSIX" LC_PAPER="POSIX" LC_NAME="POSIX" LC_ADDRESS="POSIX" LC_TELEPHONE="POSIX" LC_MEASUREMENT="POSIX" LC_IDENTIFICATION="POSIX" LC_ALL= bash-4.2$ exit ~  ```
