Intel® C++ Compiler
icc with -cxxlib-gcc
wilfried_horn
Hello!
If I try to use icc with the "-cxxlib-gcc" flag it always complains about not having found the neccessary include files.
"icpc: error: could not find directory in which the set of libstdc++ include files resides"
Could anyone help out?
Cheers!
Wilfried
TimP
To begin with, the installation of g++, from which you intendicc to adopt the library,must be working for root when you install icc. I believe it must be a gcc installation in the range 3.2.x to 3.4.x (for current icc). If you don't have such an installation of g++, you should correct it, uninstall icc, and re-install.
wilfried_horn
Hi!
First of all thanks for your help. Secondly... but that does not seem to be the problem. Though I reinstalled it (just to be sure) the same problem still exists.
To be more specific. I have a Debian unstable, with gcc and g++ 3.3.4 and a kernel 2.6.7.
Any other ideas maybe?
Cheers!
Wilfried
