Intel® C++ Compiler
7957 Discussions
icl 12 opts-out some public symbols with /Qipo
servil
trying to compile some open source project with Qipo option in effect and notice that some public symbols defined in one of sources in following form
const void *const foo[]={
&bar1,
&bar2,
&bar3,
are not accesible in final objfile, making link error LNK2001 (unresolved external symbol). All other symbols exported are accessible. I use .def file to declare exports. This error doesnot happen if compiling respective sourcefile with /Qipo only so I suppose it might be a compiler eror.
Please for advice, if that's not a regular compiler error, what switches, pragmas or declaration generally should I use to be able make this code available for linker, keeping Qipo.
This is the IntelC++ version this error encountered on:
Intel 64, Version 12.0.0.104 Build 20101006
Om_S_Intel
It is possible that these are inlined when you use /Qipo across files.
