Intel® C++ Compiler
icl error with msbuild
Steffen_Gross
After installing IntelV16 Update1 and VS2015 Update 1 , my buildprocess is broken when msbuild(14.0.24720) is used .
icl complains "icl: : error : option '/Qopt-matmul' not supported", if "Enable Matrix Multiply Library Call" is set to any other value than "Default".
Building from inside VS or with devenv is not affected.
I have attached a simple testcase for reproducing.
Bug or Feature ?
(background the real application has 287 projectfiles , and I don't want change every project by hand, as workaround I build now with devenv)
Kind Regards
Steffen
TimP
As /Qopt-matmul pertains only to Fortran, it seems a bug if any setting in a C or C++ project causes that option to be passed to ICL.  Maybe that's your point.
Steffen_Gross
I didn't see any remarks in the compiler documentation , that this flag is only for Fortran .
And on the other hand with devenv it works, also I have compared the output from msbuild (diagnostic level) started from inside Visual Studio and the commandline , and they looks identical for me . Anything I'm missed ....
Steffen_Gross
Ok , now I'm a step further .
Not /Qopt-matmul is the problem , /Qparallel is not recognized , when it is set through the properties . If I add this to the additional option on the commandline , the problem doesn't occur longer . The same thing affects also some other options (/Qopenmp,/Qstd=c++11 as example)
pbkenned1
Thanks for reporting this.  It's reproducible.  msbuild doesn't see that /Qparallel is set, and that causes /Qopt-matmul to fail:
ClCompile:
  ***** ClCompile (x64 - Intel C++)
  C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016\windows\bin\Intel64\icl.exe /c /Qm64 /Zi /W3 /O3 /Oi /Qftz /Qopt-matmul /Quse-intel-optimized-headers /D __INTEL_COMPILER=1600 /D _IPP_SEQUENTIAL_STATIC /D "__builtin
  Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20151021
  Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Done Building Project "C:\ISN_Forums\U605502\sample\TestMSB\MFCApplication1\MFC
Application1.vcxproj" (Rebuild target(s)) -- FAILED.
/Qopt-matmul is supported, but requires /Qparallel to be set.  The error message is misleading.
C:\ISN_Forums\U605502\sample\TestMSB\MFCApplication1>icl /Qopt-matmul *.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.1.146 Build 20151021
icl: command line error: option '/Qopt-matmul' not supported
C:\ISN_Forums\U605502\sample\TestMSB\MFCApplication1>icl /Qopt-matmul /Qparallel *.cpp
MainFrm.cpp
MFCApplication1.cpp
MFCApplication1Doc.cpp
MFCApplication1View.cpp
stdafx.cpp
I'll report this to the developers.
Patrick
pbkenned1
I've reported this to the developers.  I'll pass along updates I receive from them.
Internal tracking ID: DPD200380326
Patrick
