Intel® C++ Compiler
icl.exe exited with code 4 - invalid Microsoft version number: 89
Roy_v_
I recently installed Intel Parallel Studio XE 2016 and now have the Intel C++ compiler (update 4) integrated in Visual Studio 2015 (update 3).
When I create an empty c file, I can compile from the command line. However, when I take one of the sample solutions for Visual Studio I get build errors (I did run psxevars.bat):
Error    MSB6006    "icl.exe" exited with code 4.    xres5    C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Platforms\x64\PlatformToolsets\Intel C++ Compiler 16.0\Toolset.targets    377
With output log:
1>icl: : warning #10121: overriding '/Qstd=c++11' with '/Qstd:c++14'
1>  main.cpp
1>  Command-line error: invalid Microsoft version number: 89
1>
1>  compilation aborted for main.cpp (code 4)
The only related topic I could find did not give a solution to this issue:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/517998
Can anyone help me out on this issue?
SergeyKostrov
Valued Contributor II
>>...1> Command-line error: invalid Microsoft version number: 89... I just solved ( ! ) a similar problem but an error message was: ... Command-line error: invalid Microsoft version number: 20. ... when configuring a software development environment with Visual Studio 2005 and Intel C++ compiler version 11.0.075 for Itanium architecture ( aka IA-64 ). Note: ICC version 11.0.075 is the last version with support of IA-64 and can be used only with VSs 2005 and 2008. During my investigation I reviewed SetEnv.cmd from Microsoft Platform SDK for Windows Server 2003 SP1 ( 5.2.3790.1431.1 ) ( !!! ) and then "walked" through all bat-files that set the environment for IA-64 command line development. That was very unusual since I didn't expect that I would need to do some little corrections related to Microsoft Platform SDK for Windows Server 2003 SP1 bat-files.
Roy
I seem to be facing a similar issue and was hoping you could give any directions on what might cause the problem.
I'm currenlty running Visual Studio 2015 Update 3 with Intel Parallel Studio XE 17 Update 4.
***** ClCompile (x64 - Intel C++)
1>         main.cpp
1>         Command-line error: invalid Microsoft version number: 87
1>
The installation is just cleanly installed, and all Intel related variables in the path are at the beginning of the line, so the folders should surely be accessible.
- Roy
Roy
No one else facing this problem?
Hope to get this resolved.
-Roy
Czapla__Adrian
I'm facing the same problem with a clean installation of Intel System Studio 2018 Ultimate for Windows (2018.2.059).
Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
Intel(R) Compiler 18.0 Update 4 (package 253)
** Visual Studio 2017 Developer Command Prompt v15.6.7
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
E:\dev\IntelSWTools>icl test.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.4.253 Build 20180410
test.cpp
Command-line error: invalid Microsoft version number: 180
compilation aborted for test.cpp (code 4)
Adrian
Viet_H_Intel
VS2017 v15.6.7 was released on 4/26/2018; whereas Intel compiler version 18.0.4.253 was built 04/10/2018. We can't support a VS version if it didn't exist when the compiler is built.
Viet
