I recently installed Intel Parallel Studio XE 2016 and now have the Intel C++ compiler (update 4) integrated in Visual Studio 2015 (update 3).
When I create an empty c file, I can compile from the command line. However, when I take one of the sample solutions for Visual Studio I get build errors (I did run psxevars.bat):
Error MSB6006 "icl.exe" exited with code 4. xres5 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Platforms\x64\PlatformToolsets\Intel C++ Compiler 16.0\Toolset.targets 377
With output log:
1>icl: : warning #10121: overriding '/Qstd=c++11' with '/Qstd:c++14'
1> main.cpp
1> Command-line error: invalid Microsoft version number: 89
1>
1> compilation aborted for main.cpp (code 4)
The only related topic I could find did not give a solution to this issue:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/517998
Can anyone help me out on this issue?
I seem to be facing a similar issue and was hoping you could give any directions on what might cause the problem.
I'm currenlty running Visual Studio 2015 Update 3 with Intel Parallel Studio XE 17 Update 4.
***** ClCompile (x64 - Intel C++)
1> main.cpp 1> Command-line error: invalid Microsoft version number: 87 1> 1> compilation aborted for main.cpp (code 4)
The installation is just cleanly installed, and all Intel related variables in the path are at the beginning of the line, so the folders should surely be accessible.
- Roy
No one else facing this problem?
Hope to get this resolved.
-Roy
I'm facing the same problem with a clean installation of Intel System Studio 2018 Ultimate for Windows (2018.2.059).
Copyright (C) 1985-2018 Intel Corporation. All rights reserved. Intel(R) Compiler 18.0 Update 4 (package 253) ********************************************************************** ** Visual Studio 2017 Developer Command Prompt v15.6.7 ** Copyright (c) 2017 Microsoft Corporation ********************************************************************** [vcvarsall.bat] Environment initialized for: 'x64' E:\dev\IntelSWTools>icl test.cpp Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.4.253 Build 20180410 Copyright (C) 1985-2018 Intel Corporation. All rights reserved. test.cpp Command-line error: invalid Microsoft version number: 180 compilation aborted for test.cpp (code 4) E:\dev\IntelSWTools>
Adrian
VS2017 v15.6.7 was released on 4/26/2018; whereas Intel compiler version 18.0.4.253 was built 04/10/2018. We can't support a VS version if it didn't exist when the compiler is built.
Viet
