Shouldn't "iclvars.bat" put the Intel lib directory in the PATH environment variable? I am pretty sure that this caused some linkage problems when I tried to build STLPort with ICL 9.0.
Couldn't hurt, could it?
You will need the correct library paths in order to link with ICL, with or without any of the static options, with or without stlport. If you compiled with stlport headers, you must link against stlport libraries, so those must come ahead of the MSVC STL in the link. Chances are, a mixture of stlport and MSVC STL will not work.
>>Chances are, a mixture of stlport and MSVC STL will not work. <<
Well, Microsoft didn't put any of the
(The other reason being that I discovered that Microsoft didn't include any import library files for the dynamic CRT with the free toolkit...:( )
