I am getting the following errors on a simple c++ programme and was wondering if anyone knew of a solution:
$ make
icpc -ansi -O2 -w1 -std=c++0x -I/usr/include/boost -c -o YYY.o YYY.cc
/usr/include/c++/4.6.1/type_traits(74): error: identifier "constexpr" is undefined
static constexpr _Tp value = __v;
/usr/include/c++/4.6.1/type_traits(74): error: expected a ";"
/usr/include/c++/4.6.1/type_traits(75): error: member "std::integral_constant<_Tp, __v>::_Tp" is not a type name
typedef _Tp value_type;
/usr/include/c++/4.6.1/type_traits(76): error: member "std::integral_constant<_Tp, __v>::_Tp" is not a type name
typedef integral_constant<_Tp, __v> type;
/usr/include/c++/4.6.1/type_traits(77): error: identifier "constexpr" is undefined
constexpr operator value_type() { return value; }
/usr/include/c++/4.6.1/type_traits(87): error: identifier "constexpr" is undefined
constexpr _Tp integral_constant<_Tp, __v>::value;
/usr/include/c++/4.6.1/type_traits(87): error: "_Tp" is not a function or static data member
/usr/include/c++/4.6.1/type_traits(644): error: identifier "__is_literal_type" is undefined
: public integral_constant
/usr/include/c++/4.6.1/type_traits(644): error: function call is not allowed in a constant expression
/usr/include/c++/4.6.1/type_traits(644): error: type name is not allowed
/usr/include/c++/4.6.1/type_traits(648): error: expected a ";"
typename add_rvalue_reference<_Tp>::type declval() noexcept;
/usr/include/c++/4.6.1/type_traits(695): error: identifier "noexcept" is undefined
{ static const bool __value = noexcept(_Tp(declval<_Args>()...)); };
/usr/include/c++/4.6.1/type_traits(695): error: function call is not allowed in a constant expression
/usr/include/c++/4.6.1/type_traits(700): error: identifier "noexcept" is undefined
static const bool __value = noexcept(static_cast<_Tp>(declval<_Arg>()));
/usr/include/c++/4.6.1/type_traits(700): error: function call is not allowed in a constant expression
/usr/include/c++/4.6.1/type_traits(1132): error: expected a ";"
declval() noexcept
/usr/include/c++/4.6.1/type_traits(1215): error: a template argument list is not allowed in a declaration of a primary template
struct result_of<_Functor(_ArgTypes...)>
/usr/include/c++/4.6.1/bits/stl_pair.h(75): error: identifier "constexpr" is undefined
constexpr piecewise_construct_t piecewise_construct = piecewise_construct_t();
/usr/include/c++/4.6.1/bits/stl_pair.h(75): error: expected a ";"
/usr/include/c++/4.6.1/bits/stl_pair.h(99): error: identifier "constexpr" is undefined
_GLIBCXX_CONSTEXPR pair()
/usr/include/c++/4.6.1/bits/stl_pair.h(99): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/bits/stl_pair.h(100): error: expected a ";"
: first(), second() { }
/usr/include/c++/4.6.1/bits/stl_pair.h(140): error: expected a ")"
pair(piecewise_construct_t,
/usr/include/c++/4.6.1/bits/stl_pair.h(140): error: not a valid member class or function template declaration
/usr/include/c++/4.6.1/bits/stl_pair.h(140): error: expected a ";"
/usr/include/c++/4.6.1/bits/stl_pair.h(200): error: "constexpr" is not a function or static data member
inline _GLIBCXX_CONSTEXPR bool
/usr/include/c++/4.6.1/bits/stl_pair.h(277): error: expected a ";"
} // namespace
/usr/include/c++/4.6.1/initializer_list(60): error: identifier "constexpr" is undefined
constexpr initializer_list(const_iterator __a, size_type __l)
/usr/include/c++/4.6.1/initializer_list(60): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/initializer_list(61): error: expected a ";"
: _M_array(__a), _M_len(__l) { }
/usr/include/c++/4.6.1/initializer_list(85): error: "constexpr" is not a function or static data member
constexpr const _Tp*
/usr/include/c++/4.6.1/initializer_list(98): error: expected a ";"
/usr/include/c++/4.6.1/bits/stl_iterator.h(717): error: identifier "constexpr" is undefined
_GLIBCXX_CONSTEXPR __normal_iterator() : _M_current(_Iterator()) { }
/usr/include/c++/4.6.1/bits/stl_iterator.h(717): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/bits/stl_iterator.h(717): error: expected a ";"
/usr/include/c++/4.6.1/bits/char_traits.h(97): error: expected a ";"
static _GLIBCXX_CONSTEXPR bool
/usr/include/c++/4.6.1/bits/char_traits.h(123): error: member "__gnu_cxx::char_traits<_CharT>::constexpr" is not a type name
static _GLIBCXX_CONSTEXPR char_type
/usr/include/c++/4.6.1/bits/char_traits.h(123): error: "char_type" has already been declared in the current scope
/usr/include/c++/4.6.1/bits/char_traits.h(124): error: expected a ";"
to_char_type(const int_type& __c)
/usr/include/c++/4.6.1/bits/char_traits.h(147): error: class template "__gnu_cxx::char_traits<_CharT>" has no member "compare"
compare(const char_type* __s1, const char_type* __s2, std::size_t __n)
/usr/include/c++/4.6.1/bits/char_traits.h(147): error: identifier "char_type" is undefined
/usr/include/c++/4.6.1/bits/char_traits.h(160): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
length(const char_type* __p)
/usr/include/c++/4.6.1/bits/char_traits.h(160): error: declaration is incompatible with "std::size_t={unsigned long} __gnu_cxx::char_traits<_CharT>::length(const _CharT *)" (declared at line 109)
/usr/include/c++/4.6.1/bits/char_traits.h(169): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
const typename char_traits<_CharT>::char_type*
/usr/include/c++/4.6.1/bits/char_traits.h(171): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
find(const char_type* __s, std::size_t __n, const char_type& __a)
/usr/include/c++/4.6.1/bits/char_traits.h(171): error: declaration is incompatible with "const _CharT *__gnu_cxx::char_traits<_CharT>::find(const _CharT *, std::size_t={unsigned long}, const _CharT &)" (declared at line 112)
/usr/include/c++/4.6.1/bits/char_traits.h(180): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
/usr/include/c++/4.6.1/bits/char_traits.h(182): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
move(char_type* __s1, const char_type* __s2, std::size_t __n)
/usr/include/c++/4.6.1/bits/char_traits.h(182): error: declaration is incompatible with "_CharT *__gnu_cxx::char_traits<_CharT>::move(_CharT *, const _CharT *, std::size_t={unsigned long})" (declared at line 115)
/usr/include/c++/4.6.1/bits/char_traits.h(189): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
/usr/include/c++/4.6.1/bits/char_traits.h(191): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
copy(char_type* __s1, const char_type* __s2, std::size_t __n)
/usr/include/c++/4.6.1/bits/char_traits.h(191): error: declaration is incompatible with "_CharT *__gnu_cxx::char_traits<_CharT>::copy(_CharT *, const _CharT *, std::size_t={unsigned long})" (declared at line 118)
/usr/include/c++/4.6.1/bits/char_traits.h(199): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
/usr/include/c++/4.6.1/bits/char_traits.h(201): error: member "__gnu_cxx::char_traits<_CharT>::char_type" is not a type name
assign(char_type* __s, std::size_t __n, char_type __a)
/usr/include/c++/4.6.1/bits/char_traits.h(201): error: no instance of overloaded function "__gnu_cxx::char_traits<_CharT>::assign" matches the specified type
/usr/include/c++/4.6.1/bits/char_traits.h(247): error: expected a ";"
/usr/include/c++/4.6.1/bits/char_traits.h(318): error: expected a ";"
/usr/include/c++/4.6.1/bits/char_traits.h(397): error: expected a ";"
/usr/include/c++/4.6.1/bits/char_traits.h(490): error: expected a ";"
/usr/include/c++/4.6.1/bits/allocator.h(212): error: identifier "constexpr" is undefined
constexpr allocator_arg_t allocator_arg = allocator_arg_t();
/usr/include/c++/4.6.1/bits/allocator.h(212): error: expected a ";"
/usr/include/c++/4.6.1/tuple(69): error: identifier "constexpr" is undefined
constexpr _Head_base()
/usr/include/c++/4.6.1/tuple(69): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/tuple(70): error: expected a ";"
: _Head() { }
/usr/include/c++/4.6.1/tuple(93): error: identifier "constexpr" is undefined
/usr/include/c++/4.6.1/tuple(93): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/tuple(94): error: expected a ";"
: _M_head_impl() { }
/usr/include/c++/4.6.1/tuple(157): error: identifier "constexpr" is undefined
constexpr _Tuple_impl()
/usr/include/c++/4.6.1/tuple(157): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/tuple(158): error: expected a ";"
: _Inherited(), _Base() { }
/usr/include/c++/4.6.1/tuple(235): error: identifier "constexpr" is undefined
constexpr tuple()
/usr/include/c++/4.6.1/tuple(235): error: member function with the same name as its class must be a constructor
constexpr tuple()
/usr/include/c++/4.6.1/tuple(236): error: expected a ";"
: _Inherited() { }
/usr/include/c++/4.6.1/tuple(320): error: identifier "constexpr" is undefined
constexpr tuple()
/usr/include/c++/4.6.1/tuple(320): error: member function with the same name as its class must be a constructor
constexpr tuple()
/usr/include/c++/4.6.1/tuple(321): error: expected a ";"
: _Inherited() { }
/usr/include/c++/4.6.1/tuple(418): error: identifier "constexpr" is undefined
constexpr tuple()
/usr/include/c++/4.6.1/tuple(418): error: member function with the same name as its class must be a constructor
constexpr tuple()
/usr/include/c++/4.6.1/tuple(419): error: expected a ";"
: _Inherited() { }
/usr/include/c++/4.6.1/tuple(758): error: expected a ";"
const _Swallow_assign ignore{};
/usr/include/c++/4.6.1/tuple(788): error: class template "std::pair<_T1, _T2>" has no member "__cons"
__cons(tuple<_Args...>&& __tuple)
/usr/include/c++/4.6.1/tuple(799): error: class template "std::pair<_T1, _T2>" has no member "__do_cons"
__do_cons(tuple<_Args...>&& __tuple,
/usr/include/c++/4.6.1/functional(225): error: result_of is not a template
typename result_of<_Functor(_Args&&...)>::type
/usr/include/c++/4.6.1/functional(238): error: result_of is not a template
/usr/include/c++/4.6.1/functional(251): error: result_of is not a template
/usr/include/c++/4.6.1/functional(459): error: result_of is not a template
typename result_of<_Tp&(_Args&&...)>::type
/usr/include/c++/4.6.1/bits/unique_ptr.h(52): error: identifier "constexpr" is undefined
constexpr default_delete() = default;
/usr/include/c++/4.6.1/bits/unique_ptr.h(52): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/bits/unique_ptr.h(52): error: "= default" can only appear on default constructors, copy constructors, copy assignment operators, and destructors
/usr/include/c++/4.6.1/bits/unique_ptr.h(73): error: identifier "constexpr" is undefined
/usr/include/c++/4.6.1/bits/unique_ptr.h(73): error: member function with the same name as its class must be a constructor
/usr/include/c++/4.6.1/bits/unique_ptr.h(73): error: "= default" can only appear on default constructors, copy constructors, copy assignment operators, and destructors
/usr/include/c++/4.6.1/bits/unique_ptr.h(114): error: identifier "constexpr" is undefined
constexpr unique_ptr()
compilation aborted for YYY.cc (code 4)
make: *** [YYY.o] Error 4
Does specifying -U__GXX_EXPERIMENTAL_CXX0X__ on the command line help?
This should turn off C++0x extensions in the Gnu header files like constexpr which our compiler does not yet support.
Judy
Judy
Yes it would have been nice ifthe authors of the Gnu C++ libraryhad conditionalized each C++0x feature in their headers with a different macro so the Intel compiler could have turned on justthe ones we support.
Unfortunately Intel 12.1 does not support some of the C++0xfeatures inGNU 4.6 and later. It is very hard to keep ahead or even stay evenwith the latestGNU versions. Sorry for the inconvenience.
If you use GNU 4.5 or earlier you should be ok.
Judy
Judy
