Intel® C++ Compiler
7833 Discussions
icpc 12.1 and gcc 4.6, undefined reference to `__builtin_signbit'
woodbird
The following simple codes compiles successfully with g++ 4.6 but failed with icpc 12.1, update 7, on ubuntu 11.10, boost 1.46.1
=== begin of code ===
#include
int main ()
double x = boost::math::gamma_p_inv(0.5, 0.5);
return 0;
=== end of code ===
=== begin compilation commands used ===
icpc -o foo foo.cpp -std=c++0x
=== end compilation commands used ===
The compilation fails with the error as stated in the title of this thread: undefined reference to `__builtin_signbit'.
Many other boost involved codes fails with the same or similar errors, and yet another many fails with all kinds of errors while using icpc with gcc 4.6.
If I disable the `std=c++0x` flag, a lot more errors are generated.
TimP
Black Belt
Are you saying that it works with an earlier version of gcc combined with icpc?
I got the same undefined references using red hat gcc 4.4.4 or 4.7 with icpc 12.1.1 and red hat boost.
icpc 12.1.1 appears to have caught up to g++ in the syntax used here but not in implementation of builtins.
woodbird
I mean the code compile sucessfully with g++ (no icpc involved at all). But failed with icpc 12.1 when used on a platform with g++ 4.6. However, the same code successfully compile with icpc when used on Mac OS X(but that is totally another story and I don't think is releavant here, since Apple now don't even deliver pure gcc/g++ in Xcode 4.2, they supply llvm-gcc, etc)
Update: I just tested it on Red hat Linux 6.2 beta, with boost 1.47, and gcc/g++ 4.4.6, the same error remains. It happends also for the systems's default boost 1.41
Judith_W_Intel
This is already entered in our bug tracking system as cq #172180.
Here is a description of the problem:
When compiling and linking the attached program with icc, there is an undefined reference to the symbol __builtin_signbit. The progam compiles and links as expected using g++.
Sample program:
int main() {
double a = 0.0;
if (__builtin_signbit(a)) {
return 1;
return 0;
This defect was found when trying to build gzip 1.4 "out of the box" with icc.
It's on the "Must Fix" list for our next update so I expect it will be fixed soon.
Judy
Om_S_Intel
I will update the thread when the issue is fixed by INtel compiler development team.
Om_S_Intel
The issue is fixed in latest Intel C++ Composer XE 2011. The composer is available from "Intel Regiatration and Download Center".
drMikeT
how can I make intel C/C++ (12.1.x) use a GCC installation different from the "system" one which is way out of date?
The kernel came was built with GCC 4.1.2 which supports very little of c++0x features but we have users who need to use some of the latest c++0x features.
Is there any known undesirable effect from making intel C/C++ use a different GCC as a basis ? Can we switch at will among GCC installations?
best regards
michael
TimP
Black Belt
It's only necessary to put the g++ you want first on PATH and LD_LIBRARY_PATH, so that g++ -v shows you the intended version.
If you were to rebuild the kernel, or a driver which refers to kernel source, you might have a case for reverting to the corresponding gcc version for that task.
Most current linux distros which provide a gcc 4.1 kernel also provide an optional gcc/gcc++ of at least version 4.4.
For C++0x features you likely want a recent g++ 4.6 to go with icpc 12.1, and you may wish to upgrade to a current g++ when icpc 13.0 is released. You may wish to avoid mixing C++ .o files built with different major underlying versions of g++.
I give only personal opinion based on limited experience on this subject.
drMikeT
Thanks Tim, I will install a recent GCC for our oldish RHEL environment. Do you think there is any benefit to use C/C++ 13.x on a non-sandy/ivy bridge architecture?
mike
TimP
Black Belt
An evident advantage of icpc 13.0 is compatibility with g++ 4.7. There are cases of performance improvement for earlier architectures, as well as improved support for AVX, AVX2 (not yet in released hardware) and MIC.
