The following program provokes an internal compiler error in icpc 13.0.0 betawith the gcc 4.7 standard library on Fedora 17:
#include
int main(){return 0;}
The build output is:-
make[1]: Entering directory `/home/imk/develop/coan-5.0/non-dist-builds/linux/icc/sandbox'
icpc -c "/home/imk/develop/coan-5.0/non-dist-builds/linux/icc/sandbox/main.cpp" -g -O0 -Wall -std=c++0x -isystem=/usr/include/c++/4.7.0 -o ./Debug/main.o -I. -I.
/usr/include/c++/4.7.0/bits/shared_ptr_base.h(247): internal error: assertion failed at: "shared/cfe/edgcpfe/expr.c", line 5379
while (!__atomic_compare_exchange_n(&_M_use_count, &__count, __count + 1,
compilation aborted for /home/imk/develop/coan-5.0/non-dist-builds/linux/icc/sandbox/main.cpp (code 4)
make[1]: *** [Debug/main.o] Error 4
make[1]: Leaving directory `/home/imk/develop/coan-5.0/non-dist-builds/linux/icc/sandbox'
make: *** [All] Error 2
Since I don't have access to a Fedora 17 system, can you providea preprocessed file please? Just compile the file ex.cppnormally but adding the -P option, i.e. compile ex.cpp
// ex.cpp
#include
int main() { return 0; }
icpc -P -std=c++0x -isystem=/usr/include/c++/4.7.0-cex.cpp
and then attach the ex.i file to your reply. this will contain all the code in the system headers.
thanks
Judy
Also what beta version are you using? We believe this may be fixed in the latest beta update.
thanks
Judy
Hi, yes its fixed i have the sample recompile under openSUSE 12.2 Beta2 64 Bit with the Intel Parallel Studio XE 2013 Beta
(2013.0.060 update)
no problems , no erroes
(2013.0.060 update)
