Intel® C++ Compiler
7877 Discussions
icpc 15.0.0 internal errors when compiling C++11
Jae-hyeon_P_
I encountered two types of icpc internal errors when compiling some C++11 source files.  They look like:
$ icpc -std=c++11 -S lattice_numerical_constraint.ii
Internal error loop: assertion failed: find_seq_in_lookup_table: seq_number not found (shared/cfe/edgcpfe/il.c, line 3941)
compilation aborted for lattice_numerical_constraint.ii (code 4)
and
$ icpc -std=c++11 -S fmssm_lattice_mz_constraint.ii
": internal error: ** segmentation violation signal raised **
Access violation or stack overflow. Please contact Support.
compilation aborted for fmssm_lattice_mz_constraint.ii (code 4)
The .ii files were generated by icpc -E.  The two preprocessed source files and the output from icpc -v are in the attachment.  Thank you.
Alexander_W_Intel
thanks for raising this issue and including the preprocessed files. I was able to reproduce the issue and will escalate this to you engineering team after further investigations.
Alex
