Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
icpc and gprof
Hi
I am using icpc compiler to run my C++ code on Linux. I am trying to use gprof for profiling the code. I
have used the "-p" option with icpc while compiling the code. I have then executed the code which apart from its own
output also creates a gmon.out file. In order to interpret the profiling information, I need to run gprof. I
am doing this as follows: gprof myExecutable gmon.out > profiling.txt
However I get an error: myExecutable not in a.out format.
Any pointers on what could be going wrong? Is icpc compatible with gprof?
