Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
icpc bug enable_if
asd__asdqwe
The following code doesn't compile with icpc 15.0.0.090 Build 20140723, with -std=c++11.
#include <cstdlib>
#include <typeinfo>
#include <iostream>
#include <type_traits>
struct A {
    double** m;
struct B {
    double* m;
template<class T, typename std::enable_if<std::is_pointer<T>::value>::type* = nullptr>
static inline void foo(T* const& pt) {
    std::cout << "bar 1" << std::endl;
template<class T, typename std::enable_if<!std::is_pointer<T>::value>::type* = nullptr>
    std::cout << "bar 2" << std::endl;
int main() {
    A a;
    foo(a.m);
    B b;
    foo(b.m);
On the other hand, with g++ and clang++, I get the expected output:
bar 1
bar 2
Thank you in advance for looking into this.
Feilong_H_Intel
Hi there,
I reproduced the problem.  And I'm entering it to our problem-tracking database.
Feilong_H_Intel
Engineering team is looking into this issue.  Meanwhile, they provided a temporary workaround for you.  See the code snippet below.
//template<class T, typename std::enable_if<std::is_pointer<T>::value>::type* = nullptr>
template<class T, typename std::enable_if<std::is_pointer<T>::value>::type* = (void*)0>
//template<class T, typename std::enable_if<!std::is_pointer<T>::value>::type* = nullptr>
template<class T, typename std::enable_if<!std::is_pointer<T>::value>::type* = (void*)0>
asd__asdqwe
Thank you for the workaround.
asd__asdqwe
This still doesn't compile properly with icpc 15.0.2.132.
