I am trying to compile SuiteSparse 5.10.1 with the "Intel parallel studio xe 2020 r0".
[spackapps@eu-a6-008-07 bin]$ icpc --version
icpc (ICC) 19.1.0.166 20191121
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
I explicitly set -march=core-avx2 and I see in the logs the warning:
icpc: command line warning #10121: overriding '-march=core-avx2' with '-xHOST'
How can I achieve that the Intel compiler respects my setting of march and does not replace it? If I want to optimize for the current host, then I would set -march=native. But I explicitly want to optimize for -march=core-avx2 and not for anything else.
Any help is appreciated.
Thank you and best regards
Sam
Hi Rahul,
Thank you for your feedback. I encountered this problem when compiling SuiteSparse 5.10.1 with Intel 19.1.0. I don't have any other example to reproduce this. Unfortunately there is a bug in the Intel 19.1.0 such that SuiteSparse 5.10.1 cannot be compiled successfully:
Please feel free to close this thread. It does not make sense to spend more time on this. I will switch to GCC, where compilation of most packages that I need works.
Could you provide your OS environment details?
Also, check whether AVX2 instructions are supported on your machine.
Rahul
Hi Rahul,
Thank you for your reply.
Please find below the information regarding the operating system and kernel:
[sfux@eu-login-05 ~]$ cat /etc/redhat-release
CentOS Linux release 7.9.2009 (Core)
[sfux@eu-login-05 ~]$ uname -a
Linux eu-login-05 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64 GNU/Linux
All hardware in our cluster all supports avx2 (I have compiled 100's of software packages with march=core-avx2 already):
Please find below the information about the CPU from the oldest generation of our hardware (all other nodes are have newer CPUs):
[sfux@eu-login-05 ~]$ cat /proc/cpuinfo | head -n 25
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 71
model name : Intel(R) Xeon(R) CPU E3-1284L v4 @ 2.90GHz
stepping : 1
microcode : 0x21
cpu MHz : 922.180
cache size : 6144 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb invpcid_single intel_pt ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm rdseed adx smap xsaveopt dtherm ida arat pln pts md_clear spec_ctrl intel_stibp flush_l1d
bogomips : 5799.40
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
Best regards
Sam
Dear Rahul,
[sfux@eu-login-15 ~]$ cat /etc/redhat-release
[sfux@eu-login-15 ~]$ uname -a
Linux eu-login-15 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64 GNU/Linux
[sfux@eu-login-15 ~]$ cat /proc/cpuinfo | head -n 25
processor : 0
cpu family : 6
model : 71
stepping : 1
microcode : 0x21
cpu MHz : 1012.097
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 5799.77
clflush size : 64
power management:
I don't think that it is related to the OS or the CPU model.
If I specify an option to the compiler, it should not overwritten.
Best regards
Sam
Just a quick reminder to provide the required details.
Rahul
Dear Rahul,
Thank you for the reminder. I posted my answer already twice and I don't know why this is not added to this thread. Trying for the third time:
[sfux@eu-login-28 ~]$ cat /etc/redhat-release
[sfux@eu-login-28 ~]$ uname -a
Linux eu-login-28 3.10.0-1160.31.1.el7.x86_64 #1 SMP Thu Jun 10 13:32:12 UTC 2021 x86_64 GNU/Linux
[sfux@eu-login-28 ~]$ cat /proc/cpuinfo | head -n 25
processor : 0
cpu family : 6
model : 71
stepping : 1
microcode : 0x21
cpu MHz : 947.314
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 5800.03
clflush size : 64
power management:
As you can see, the hardware supports AVX2.
Best regards
Sam
I sent the required details already 3 times, but it does not get added to this thread ...
[sfux@eu-login-29 ~]$ cat /etc/redhat-release
[sfux@eu-login-29 ~]$ uname -a
Linux eu-login-29 3.10.0-1160.31.1.el7.x86_64 #1 SMP Thu Jun 10 13:32:12 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
[sfux@eu-login-29 ~]$ cat /proc/cpuinfo | head -n 25
processor : 0
cpu family : 6
model : 71
stepping : 1
microcode : 0x21
cpu MHz : 1299.902
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 20
wp : yes
bogomips : 5799.63
clflush size : 64
power management:
Thanks for providing the required details. All your previous posts have reappeared now. Sorry for the inconvenience caused.
Do you have a minimal reproducer code that I can try out at my end?
Also, is this issue specific to a particular source code or generic?
Rahul
Hi Rahul,
Hi Samuel,
As discussed via email, we have taken note of your suggestions. We would discontinue monitoring this issue. Please raise a new thread if you have further issues.
Rahul
