Encountered on the devcloud...
icpc: error #10106: Fatal error in /glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64/mcpcom, terminated by kill signal
Command argmuments
-Wall -Wextra -wd1011 -O3 -qopenmp -std=gnu++17
Attached preprocessed source.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
It compiled OK for me.
$ icpc -Wall -Wextra -wd1011 -O3 -qopenmp -std=gnu++17 -c Filters.cpp -o Filters.o
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.3.199 Build 20190206
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
$ ls -lt Filters.o
-rw-r--r-- 1 vahoang ome 299832 Dec 13 11:48 Filters.o
What compiler version is it?
I can't untar the tar ball.
$ ls -lt Filters.cpp.bz2
-rw-r--r-- 1 vahoang ome 204825 Dec 13 09:11 Filters.cpp.bz2
$ tar -xvjf Filters.cpp.bz2
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Exiting with failure status due to previous errors
It's not a tarball... it's just a bzip-ed preprocessed source. Try bunzip?
******@login-1:~/cswarm/mrwt/build$ icpc --version icpc (ICC) 19.0.3.199 20190206 Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
******@login-1:~/temp$ bunzip2 Filters.cpp.bz2 ******@login-1:~/temp$ icpc -Wall -Wextra -wd1011 -O3 -qopenmp -std=gnu++17 -c Filters.cpp -o Filters.o icpc: error #10106: Fatal error in /glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64/mcpcom, terminated by kill signal compilation aborted for Filters.cpp (code 1) ******@login-1:~/temp$
It runs for a long time... maybe it's just running OOM? It's not giving me any information about what kind of signal I'm getting...
$ icpc -V
$ ls -lt Filters.o
Okay. I guess that it's system specific to intel's devcloud environment... maybe something ulimit based. I'll try and figure out who to contact about that. Thanks
Ok, it took about 2mins to compile, btw
Viet Hoang (Intel) wrote:Ok, it took about 2mins to compile, btw
Yeah, that's consistent with what I see. We've always had very long compiles (and ICE) with our use of "modern" C++ and icc. Generally I use clang and gcc during development cycles and then go back to icc at the end of a cycle for performance analysis. I'm looking forward to the Next version to see if icc can play a more direct role during development. I can compile on one of the compute nodes that has a newer icc and different ulimits, so I can compile Filter... now I'm just getting a normal ICE elsewhere from EDG.
