OS: Ubuntu 18.04 x86_64
Compiler version: icpc (ICC) 18.0.2 20180210
I have run into an icpc compiler bug. Intel's C++ compiler fails to compile template functions which use the non-standard __int128_t or __uint128_t types. I ran into this bug when I tried to compile my primecount program (https://github.com/kimwalisch/primecount) using icpc. I have created a minimal C++ program (see attached bug.cpp) which reproduces the bug.
Steps to reproduce the bug:
$ icpc bug.cpp
bug.cpp(28) (col. 27): internal error: 04010002_1504
compilation aborted for bug.cpp (code 4)
Thanks for your help!
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Kim,
Thanks for reporting this issue. I've submitted a bug to our developer. The case number is: CMPLRS-50210
Viet
