Hi.
I am trying to compile simple code using openmp.
Here is the code (file test.cpp):
int main() { double a[100]; #pragma omp parallel for for (int i = 0; i < 100; ++i) { a = i; } return 0; }
I compile using the following command:
icpc -openmp test.cpp
the result is:
icpc: command line error: option '-openmp' not supported
Can you help me please?
Several versions back the spelling was changed to -qopenmp. Did you check icpc -help?
-qopenmp gives the same error. Maybe i should add something to PATH for it to recognise that it can use OpenMP. I installed intel system studio, but it didn't add anything to PATH.
Dear all,
Our old cray system has ifort 13, new one has version 18. The earlier one only knows -openmp, the new one only knows -qopenmp. I need to continue using both, and compiling the same code on both. How can I write a makefile for that?
