Intel® C++ Compiler
icpc program fails with double free when it shouldn't
gn164
Hi
The following program fails with " double free or corruption" error. I believe it is a compiler bug. Could someone please have a look at it.
icpc version 14.0.1 (gcc version 4.7.0 compatibility)
icpc -std=c++11 -O2 -g streamtest.cpp
#include <iostream>
#include <stdio.h>
#include <sstream>
struct Path
   Path()
      _host = "host";
      _dir =  "dir";
      _file = "file";
   std::string host()
      return _host;
   std::string path() {
      std::string ret = host() + _dir + _file;
      return  ret;
   private:
      std::string _dir;
      std::string _file;
      std::string _host;
int main () {
  Path path;
  std::string p = path.path();
  return 0;
Viet_H_Intel
I don't have a machine with GCC 4.7 installed, but I could reproduce it with GCC 4.8.1
vahoang@orcsle100:/tmp$ icpc -std=c++11 -O2 -g t.cpp -V
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
Edison Design Group C/C++ Front End, version 4.6 (Oct  8 2013 19:20:39)
Copyright 1988-2013 Edison Design Group, Inc.
GNU ld version 2.20.51.0.2-5.11.el6 20091009
vahoang@orcsle100:/tmp$ gcc -v
gcc version 4.8.1 (GCC)
Secondly, we are no longer supported Intel compiler version 14.0.
Viet_H_Intel
Sorry for the typo. "could" where I meant "could not".
