Intel® C++ Compiler
icpc version and __INTEL_COMPILER
alexvi
Linux 2.6.18-238.1.1.el5 #1 SMP Tue Jan 4 13:32:19 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
> icpc -V
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.4.191 Build 20110427
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
// File eee.cpp
#include
int main()
std::cout << __INTEL_COMPILER << std::endl;
return 0;
> icpc eee.cpp
> ./a.out
1200
Excepted output of a.out is 1204, but actual 1200
Alex
mecej4
For this macro to do as you want, the header file would have to be updated with every release.
You could try the macro __INTEL_COMPILER_BUILD_DATE .
alexvi
Which header file should be updated with every release?
mecej4
I am not sure; at any rate, I meant that the compiler vendor would need to do the update, not the user. It is also possible that some of these are built-in macros, so they may not be accessible through a header file.
alexvi
It seems that __INTEL_COMPILER is built-in macros
