icpx icpxerr5.C
free(): invalid pointer
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: /opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang++ -cc1 -triple x86_64-unknown-linux-gnu -emit-obj --mrelax-relocations -disable-free -disable-llvm-verifier -discard-value-names -main-file-name icpxerr5.C -mrelocation-model static -fveclib=SVML -mframe-pointer=none -fmath-errno -fno-rounding-math -mconstructor-aliases -munwind-tables -target-cpu x86-64 -fno-split-dwarf-inlining -debugger-tuning=gdb -resource-dir /opt/intel/oneapi/compiler/2021.1.2/linux/lib/clang/12.0.0 -I/opt/intel/oneapi/dpcpp-ct/2021.1.1/include -I/opt/intel/oneapi/dnnl/2021.1.1/cpu_dpcpp_gpu_dpcpp/lib -I/opt/intel/oneapi/ccl/2021.1.1/include/cpu_gpu_dpcpp -I/opt/intel/oneapi/vpl/2021.1.1/include -I/opt/intel/oneapi/ipp/2021.1.1/include -I/opt/intel/oneapi/tbb/2021.1.1/env/../include -I/opt/intel/oneapi/ippcp/2021.1.1/include -I/opt/intel/oneapi/dev-utilities/2021.1.1/include -I/opt/intel/oneapi/mkl/latest/include -I/opt/intel/oneapi/mpi/2021.1.1//include -I/opt/intel/oneapi/dal/2021.1.1/include -I/opt/intel/oneapi/dpl/2021.1.2/linux/include -I/opt/intel/oneapi/compiler/2021.1.2/linux/include -cxx-isystem /opt/intel/oneapi/clck/2021.1.1/include -internal-isystem /opt/intel/oneapi/compiler/2021.1.2/linux/bin/../compiler/include -internal-isystem /home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1 -internal-isystem /home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1/x86_64-pc-linux-gnu -internal-isystem /home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1/backward -internal-isystem /usr/local/include -internal-isystem /opt/intel/oneapi/compiler/2021.1.2/linux/lib/clang/12.0.0/include -internal-externc-isystem /include -internal-externc-isystem /usr/include -O2 -fdeprecated-macro -fdebug-compilation-dir /home/vitti/f95/cc -ferror-limit 19 -disable-cpudispatch-ifuncs -fheinous-gnu-extensions -fgnuc-version=4.2.1 -fcxx-exceptions -fexceptions -fcolor-diagnostics -vectorize-loops -vectorize-slp -fintel-compatibility -mllvm -disable-hir-generate-mkl-call -mllvm -intel-libirc-allowed -mllvm -loopopt=0 -mllvm -enable-lv -o /tmp/icpxerr5-61217e.o -x c++ icpxerr5.C
1. icpxerr5.C:4:49: current parser token ';'
2. icpxerr5.C:2:22: parsing struct/union/class body 'A'
#0 0x00005602ddef78f7 llvm::sys::PrintStackTrace(llvm::raw_ostream&) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x17788f7)
#1 0x00005602ddef60b0 llvm::sys::RunSignalHandlers() (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x17770b0)
#2 0x00005602ddef7bc1 SignalHandler(int) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x1778bc1)
#3 0x0000152ce908b960 __restore_rt (/usr/lib64/libpthread.so.0+0x13960)
#4 0x0000152ce8ee4292 raise (/usr/lib64/libc.so.6+0x3d292)
#5 0x0000152ce8ecd8a4 abort (/usr/lib64/libc.so.6+0x268a4)
#6 0x0000152ce8f26cd7 __libc_message (/usr/lib64/libc.so.6+0x7fcd7)
#7 0x0000152ce8f2e94c (/usr/lib64/libc.so.6+0x8794c)
#8 0x0000152ce8f30e69 (/usr/lib64/libc.so.6+0x89e69)
#9 0x00005602e088f532 GetFullTypeForDeclarator((anonymous namespace)::TypeProcessingState&, clang::QualType, clang::TypeSourceInfo*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x4110532)
#10 0x00005602e087fa0f clang::Sema::GetTypeForDeclarator(clang::Declarator&, clang::Scope*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x4100a0f)
#11 0x00005602e125c43c clang::Sema::HandleField(clang::Scope*, clang::RecordDecl*, clang::SourceLocation, clang::Declarator&, clang::Expr*, clang::InClassInitStyle, clang::AccessSpecifier) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x4add43c)
#12 0x00005602e07bdbf4 clang::Sema::ActOnCXXMemberDeclarator(clang::Scope*, clang::AccessSpecifier, clang::Declarator&, llvm::MutableArrayRef<clang::TemplateParameterList*>, clang::Expr*, clang::VirtSpecifiers const&, clang::InClassInitStyle) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x403ebf4)
#13 0x00005602e06f88e7 clang::Parser::ParseCXXClassMemberDeclaration(clang::AccessSpecifier, clang::ParsedAttributes&, clang::Parser::ParsedTemplateInfo const&, clang::ParsingDeclRAIIObject*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f798e7)
#14 0x00005602e06fabe2 clang::Parser::ParseCXXClassMemberDeclarationWithPragmas(clang::AccessSpecifier&, clang::Parser::ParsedAttributesWithRange&, clang::TypeSpecifierType, clang::Decl*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f7bbe2)
#15 0x00005602e06f6614 clang::Parser::ParseCXXMemberSpecification(clang::SourceLocation, clang::SourceLocation, clang::Parser::ParsedAttributesWithRange&, unsigned int, clang::Decl*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f77614)
#16 0x00005602e06f3b3c clang::Parser::ParseClassSpecifier(clang::tok::TokenKind, clang::SourceLocation, clang::DeclSpec&, clang::Parser::ParsedTemplateInfo const&, clang::AccessSpecifier, bool, clang::Parser::DeclSpecContext, clang::Parser::ParsedAttributesWithRange&) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f74b3c)
#17 0x00005602e06e4053 clang::Parser::ParseDeclarationSpecifiers(clang::DeclSpec&, clang::Parser::ParsedTemplateInfo const&, clang::AccessSpecifier, clang::Parser::DeclSpecContext, clang::Parser::LateParsedAttrList*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f65053)
#18 0x00005602e070cdf0 clang::Parser::ParseSingleDeclarationAfterTemplate(clang::DeclaratorContext, clang::Parser::ParsedTemplateInfo const&, clang::ParsingDeclRAIIObject&, clang::SourceLocation&, clang::ParsedAttributes&, clang::AccessSpecifier) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f8ddf0)
#19 0x00005602e070c801 clang::Parser::ParseTemplateDeclarationOrSpecialization(clang::DeclaratorContext, clang::SourceLocation&, clang::ParsedAttributes&, clang::AccessSpecifier) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f8d801)
#20 0x00005602e070c39c clang::Parser::ParseDeclarationStartingWithTemplate(clang::DeclaratorContext, clang::SourceLocation&, clang::ParsedAttributes&, clang::AccessSpecifier) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f8d39c)
#21 0x00005602e06e32e4 clang::Parser::ParseDeclaration(clang::DeclaratorContext, clang::SourceLocation&, clang::Parser::ParsedAttributesWithRange&, clang::SourceLocation*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f642e4)
#22 0x00005602e06d5eda clang::Parser::ParseExternalDeclaration(clang::Parser::ParsedAttributesWithRange&, clang::ParsingDeclSpec*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f56eda)
#23 0x00005602e06d568c clang::Parser::ParseTopLevelDecl(clang::OpaquePtr<clang::DeclGroupRef>&, bool) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f5668c)
#24 0x00005602e11c744a clang::Parser::ParseFirstTopLevelDecl(clang::OpaquePtr<clang::DeclGroupRef>&) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x4a4844a)
#25 0x00005602e06d3258 clang::ParseAST(clang::Sema&, bool, bool) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x3f54258)
#26 0x00005602e1135b17 clang::CodeGenAction::ExecuteAction() (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x49b6b17)
#27 0x00005602e103381e clang::FrontendAction::Execute() (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x48b481e)
#28 0x00005602e0fd9a12 clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x485aa12)
#29 0x00005602e104a502 clang::ExecuteCompilerInvocation(clang::CompilerInstance*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x48cb502)
#30 0x00005602e0932a9c cc1_main(llvm::ArrayRef<char const*>, char const*, void*) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x41b3a9c)
#31 0x00005602e0931721 ExecuteCC1Tool(llvm::SmallVectorImpl<char const*>&) (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x41b2721)
#32 0x00005602e0930d72 main (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x41b1d72)
#33 0x0000152ce8eceb75 __libc_start_main (/usr/lib64/libc.so.6+0x27b75)
#34 0x00005602e092e3e2 _start (/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang+++0x41af3e2)
clang++: error: unable to execute command: Aborted (core dumped)
clang++: error: clang frontend command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++ Compiler 2021.1.2 (2020.10.0.1214)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2021.1.2/linux/bin
clang++: note: diagnostic msg:
PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
Preprocessed source(s) and associated run script(s) are located at:
clang++: note: diagnostic msg: /tmp/icpxerr5-5c068b.cpp
clang++: note: diagnostic msg: /tmp/icpxerr5-5c068b.sh
[vitti cc]$cat /tmp/icpxerr5-5c068b.cpp
# 1 "<built-in>"
# 1 "icpxerr5.C"
// icpx ICE in GetFullTypeForDeclarator
template<typename T> struct A
int x[sizeof(T)] __attribute((vector_size(8)));
[vitti cc]$cat /tmp/icpxerr5-5c068b.sh
# Crash reproducer for Intel(R) oneAPI DPC++ Compiler 2021.1.2 (2020.10.0.1214)
# Driver args: "--driver-mode=g++" "--intel" "icpxerr5.C"
# Original command: "/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang++" "-cc1" "-triple" "x86_64-unknown-linux-gnu" "-emit-obj" "--mrelax-relocations" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "icpxerr5.C" "-mrelocation-model" "static" "-fveclib=SVML" "-mframe-pointer=none" "-fmath-errno" "-fno-rounding-math" "-mconstructor-aliases" "-munwind-tables" "-target-cpu" "x86-64" "-fno-split-dwarf-inlining" "-debugger-tuning=gdb" "-resource-dir" "/opt/intel/oneapi/compiler/2021.1.2/linux/lib/clang/12.0.0" "-I/opt/intel/oneapi/dpcpp-ct/2021.1.1/include" "-I/opt/intel/oneapi/dnnl/2021.1.1/cpu_dpcpp_gpu_dpcpp/lib" "-I/opt/intel/oneapi/ccl/2021.1.1/include/cpu_gpu_dpcpp" "-I/opt/intel/oneapi/vpl/2021.1.1/include" "-I/opt/intel/oneapi/ipp/2021.1.1/include" "-I/opt/intel/oneapi/tbb/2021.1.1/env/../include" "-I/opt/intel/oneapi/ippcp/2021.1.1/include" "-I/opt/intel/oneapi/dev-utilities/2021.1.1/include" "-I/opt/intel/oneapi/mkl/latest/include" "-I/opt/intel/oneapi/mpi/2021.1.1//include" "-I/opt/intel/oneapi/dal/2021.1.1/include" "-I/opt/intel/oneapi/dpl/2021.1.2/linux/include" "-I/opt/intel/oneapi/compiler/2021.1.2/linux/include" "-cxx-isystem" "/opt/intel/oneapi/clck/2021.1.1/include" "-internal-isystem" "/opt/intel/oneapi/compiler/2021.1.2/linux/bin/../compiler/include" "-internal-isystem" "/home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1" "-internal-isystem" "/home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1/x86_64-pc-linux-gnu" "-internal-isystem" "/home/vitti/local/gcc-150321-full/lib/gcc/x86_64-pc-linux-gnu/11.0.1/../../../../include/c++/11.0.1/backward" "-internal-isystem" "/usr/local/include" "-internal-isystem" "/opt/intel/oneapi/compiler/2021.1.2/linux/lib/clang/12.0.0/include" "-internal-externc-isystem" "/include" "-internal-externc-isystem" "/usr/include" "-O2" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/vitti/f95/cc" "-ferror-limit" "19" "-disable-cpudispatch-ifuncs" "-fheinous-gnu-extensions" "-fgnuc-version=4.2.1" "-fcxx-exceptions" "-fexceptions" "-fcolor-diagnostics" "-vectorize-loops" "-vectorize-slp" "-fintel-compatibility" "-mllvm" "-disable-hir-generate-mkl-call" "-mllvm" "-intel-libirc-allowed" "-mllvm" "-loopopt=0" "-mllvm" "-enable-lv" "-o" "/tmp/icpxerr5-61217e.o" "-x" "c++" "icpxerr5.C"
"/opt/intel/oneapi/compiler/2021.1.2/linux/bin/clang++" "-cc1" "-triple" "x86_64-unknown-linux-gnu" "-emit-obj" "--mrelax-relocations" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "icpxerr5.C" "-mrelocation-model" "static" "-fveclib=SVML" "-mframe-pointer=none" "-fmath-errno" "-fno-rounding-math" "-mconstructor-aliases" "-munwind-tables" "-target-cpu" "x86-64" "-fno-split-dwarf-inlining" "-debugger-tuning=gdb" "-cxx-isystem" "/opt/intel/oneapi/clck/2021.1.1/include" "-O2" "-fdeprecated-macro" "-ferror-limit" "19" "-disable-cpudispatch-ifuncs" "-fheinous-gnu-extensions" "-fgnuc-version=4.2.1" "-fcxx-exceptions" "-fexceptions" "-fcolor-diagnostics" "-vectorize-loops" "-vectorize-slp" "-fintel-compatibility" "-mllvm" "-disable-hir-generate-mkl-call" "-mllvm" "-intel-libirc-allowed" "-mllvm" "-loopopt=0" "-mllvm" "-enable-lv" "-x" "c++" "icpxerr5-5c068b.cpp"
Hi Vittorio,
Thanks for reporting the ICE.
We are looking into it and will get back to you soon.
Prasanth
Vector types work differently in LLVM compares to GNU. If you compile the test case with clang++ you would get the same error.
Viet
I am going to close this thread as it is not an issue with icpx/clang++.
I believe icpx should issue a meaningful and helpful error message as in
invalid vector element type 'int [sizeof(T)]' from clang++ version 12.
It should not crash with a request of a bug report.
Yes, you will see this message with the next update version.
t1.cpp:3:31: error: invalid vector element type 'int [sizeof(T)]'
