The following code provokes an ICE in icpx Version 2021.1 NextGen Beta Build 20200304
// icpx -fpermissive ICE in IntExprEvaluator::VisitCastExpr
enum E { EA, EB };
struct A { E e: 8; };
A a = { 0 };
Hi Vittorio,
You are getting an error because you cannot convert an enum into int type a.
But since you are using -fpermissive, it will make the compiler to report some things that are actually errors (but are permitted by some compilers) as warnings, to permit code to compile even if it doesn't conform to the language rules.
You will get the same error with g++, icpc or clang++.
What is the use case you are trying to achieve?
Prasanth
g++ -fpermissive compiles with a warning, while icpc -fpermissive compiles without warnings.
This snippet code is part of a huge code that compiles and run with g++ -fpermissive
AND with icpc -fpermissive.
I do not understand why icpx crashes, instead of just giving an error message
and gracefully terminate.
The compiler shouldn't give you a core dump. I'll report that to our Developer.
If you have later icpx version, then -fpermissive (for gnu extension for non conformant code) won't longer be supported (I think it's because clang doesn't support it)
$ cat t4.cpp
enum E { EA, EB };
A a = { 0 };
$ icpc t4.cpp -fpermissive -c
$ g++ t4.cpp -fpermissive -c
t4.cpp:5:11: warning: invalid conversion from ‘int’ to ‘E’ [-fpermissive]
A a = { 0 };
$ clang++ t4.cpp -fpermissive -c
error: unknown argument: '-gnu-permissive'
$ icpx t4.cpp -fpermissive -c
You can use -fgnu-keywords for Gnu extension with icpx instead
$ clang++ t4.cpp -c -fgnu-keywords
t4.cpp:5:9: error: cannot initialize a member subobject of type 'E' with an rvalue of type 'int'
A a = { 0 };
1 error generated.
$ icpx t4.cpp -c -fgnu-keywords
A a = { 0 };
1 error generated.
Keep in mind that icpx is compatible with clang, so you may find issues when porting from icpc/g++ to icpx/clang.
This issue has been resolved in oneAPI 2021.1.2. We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
