cat icxerr2.c
// icx ICE in X86ISelLowering.cpp
struct S { int c, *b, *e; };
void
foo ()
struct S a;
asm volatile ("" : "=rm" (a) : "0" (1));
}icx icxerr2.c
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: /opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang -cc1 -triple x86_64-unknown-linux-gnu -emit-obj --mrelax-relocations -disable-free -disable-llvm-verifier -discard-value-names -main-file-name icxerr2.c -mrelocation-model static -fveclib=SVML -mframe-pointer=none -menable-no-infs -menable-no-nans -menable-unsafe-fp-math -fno-signed-zeros -mreassociate -freciprocal-math -fdenormal-fp-math=preserve-sign,preserve-sign -ffp-contract=fast -fno-rounding-math -ffast-math -ffinite-math-only -mconstructor-aliases -munwind-tables -target-cpu x86-64 -mllvm -x86-enable-unaligned-vector-move=true -tune-cpu generic -debugger-tuning=gdb -fcoverage-compilation-dir=/home/vitti/f95/cc -resource-dir /opt/intel/oneapi/compiler/2021.3.0/linux/lib/clang/13.0.0 -I/opt/intel/oneapi/vpl/2021.4.0/include -I/opt/intel/oneapi/tbb/2021.3.0/env/../include -I/opt/intel/oneapi/mpi/2021.3.0//include -I/opt/intel/oneapi/mkl/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/ippcp/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/dpl/2021.4.0/linux/include -I/opt/intel/oneapi/dpcpp-ct/2021.3.0/include -I/opt/intel/oneapi/dnnl/2021.3.0/cpu_dpcpp_gpu_dpcpp/lib -I/opt/intel/oneapi/dev-utilities/2021.3.0/include -I/opt/intel/oneapi/dal/2021.3.0/include -I/opt/intel/oneapi/compiler/2021.3.0/linux/include -I/opt/intel/oneapi/ccl/2021.3.0/include/cpu_gpu_dpcpp -I/opt/intel/oneapi/vpl/2021.4.0/include -I/opt/intel/oneapi/tbb/2021.3.0/env/../include -I/opt/intel/oneapi/mpi/2021.3.0//include -I/opt/intel/oneapi/mkl/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/ippcp/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/dpl/2021.4.0/linux/include -I/opt/intel/oneapi/dpcpp-ct/2021.3.0/include -I/opt/intel/oneapi/dnnl/2021.3.0/cpu_dpcpp_gpu_dpcpp/lib -I/opt/intel/oneapi/dev-utilities/2021.3.0/include -I/opt/intel/oneapi/dal/2021.3.0/include -I/opt/intel/oneapi/compiler/2021.3.0/linux/include -I/opt/intel/oneapi/ccl/2021.3.0/include/cpu_gpu_dpcpp -cxx-isystem /opt/intel/oneapi/clck/2021.3.0/include -cxx-isystem /opt/intel/oneapi/clck/2021.3.0/include -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/bin/../compiler/include -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/lib/clang/13.0.0/include -internal-isystem /usr/local/include -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../x86_64-redhat-linux/include -internal-externc-isystem /include -internal-externc-isystem /usr/include -O2 -fdebug-compilation-dir=/home/vitti/f95/cc -ferror-limit 19 -fheinous-gnu-extensions -fgnuc-version=4.2.1 -fcolor-diagnostics -vectorize-loops -vectorize-slp -D__GCC_HAVE_DWARF2_CFI_ASM=1 -fintel-compatibility -mllvm -disable-hir-generate-mkl-call -mllvm -intel-libirc-allowed -mllvm -loopopt=0 -mllvm -enable-lv -o /tmp/icxerr2-3981a5.o -x c icxerr2.c
1. <eof> parser at end of file
2. Code generation
3. Running pass 'Function Pass Manager' on module 'icxerr2.c'.
4. Running pass 'X86 DAG->DAG Instruction Selection' on function ''
#0 0x000055b8b3e5968a llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+0x438f68a)
#1 0x000055b8b3e59430 llvm::sys::RunSignalHandlers() (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+0x438f430)
#2 0x000055b8b3e59914 SignalHandler(int) (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+0x438f914)
#3 0x000014ad9e0e7a20 (/usr/lib64/libpthread.so.0+0x13a20)
#4 0x000055b8b28ae908 (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+0x2de4908)
clang: error: unable to execute command: Trace/breakpoint trap (core dumped)
clang: error: clang frontend command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2021.3.0 (2021.3.0.20210619)
Target: x86_64-unknown-linux-gnu
Thread model: posix
we are able to reproduce the error at our end. We are working on your issue and we will get back to you soon.
Thanks & regards,
Santosh
