Intel® C++ Compiler
7954 Discussions
icx error: wrong code (output `Segmentation fault`) at -O2 since `x86-64 icx 2023.2.0`
Junwei_Zeng
I compiled the following code with icx at -O2, and it produces the wrong code, outputting the error `Segmentation fault (core dumped)`.
I found this bug was introduced starting from `x86-64 icx-2023.2.0`.
$ cat test.c
int c[56];
int f, a, d, h;
long b;
static int e;
static long k;
int *g = &a;
void l(char m) { f = c[(int) m]; }
void n() {
  long *i[] = {&k, &b};
  for (; e <= 4; e++) {
    short j = 5527;
    h = 0;
    for (; h <= 1; h++) {
      d = 0;
      for (; d <= 1; d++) {
        if (k)
          break;
        ++j;
    *g = e;
    l(j >> 8);
int main() { n(); }
$ icx -O0 test.c; ./a.out
$ icx -O1 test.c; ./a.out
$ icx -Os test.c; ./a.out
$ icx -O3 test.c; ./a.out
$ icx -O2 test.c; ./a.out
$ gcc-13 -O2 test.c; ./a.out
$ icx --version
Intel(R) oneAPI DPC++/C++ Compiler 2023.2.0 (2023.2.0.20230622)
Target: x86_64-unknown-linux-gnu
$ gcc-13 --version
gcc (Compiler-Explorer-Build-gcc--binutils-2.40) 13.2.0
Copyright (C) 2023 Free Software Foundation, Inc.
Junwei Zeng.
SeshaP_Intel
Thank you for your patience. The issue raised by you has been targeted to be fixed in the oneAPI 2024.1 version which will released in the coming months.
If the issue still persists with the new release, then you can start a new discussion for the community to investigate.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We are working on your issue internally. We will get back to you soon.
Thanks and Regards,
SeshaP_Intel
Thanks and Regards,
Junwei_Zeng
Thank you for your prompt reply and confirmation. It's great to hear that this issue has been targeted to be fixed in the Intel oneAPI 2024.1 version.
Once the new version is available, I'll thoroughly test it to ensure the issue has been resolved. Should any concerns persist, I won't hesitate to reach out and seek further assistance from the community.
Again, thank you for your assistance in this matter.
Junwei Zeng.
